b18c 500whp build
Old May 18, 2015 | 12:54 PM
m0sad's Avatar
Default b18c 500whp build
My goal 500whp (mustang dyno) about 550whp at dynojet
Block:
b18c4
9.0:1 CP's
81.5mm
Manley TT rods
ARP SS head studs
GE HeadGasket
ACL Race bearings
OEM crankshaft
OEM oil pump (ported)
Head:
BC valvetrain
CTR cams
Ferrea 6000 valves
custom head work
victorX manifold
oem throttle
1000cc precision injectors
AEM fuel rail
Aeromotive FPR
Setup:
6262 JB 82.ar
Custom EX mani (ramhorn)
3' downpipe all the way
AEM fuel pump
2.5 IC piping
Big custom FMIC
MSD distributer, bluster, coil, wires.
AEM W/m kit
Transmission:
s9b tranny
OEM LSD
comp STG 5, 4 pads clutch.
stock axels.
225/50/15 R888
the car is going to be a street car only, not getting near a track.
so far we tune on the street, pump gas + meth.
blew up 2 OEM coils, so i got the MSD kit.
any comment will be appreciated [=
(pic will be add later. )
Old May 18, 2015 | 01:13 PM
boosted94gsr's Avatar
Default Re: b18c 500whp build
Sounds like a solid setup. What are you using for engine management? What size nozzle are you using with the AEM w/m kit?
Old May 18, 2015 | 01:23 PM
NotARaCist's Avatar
I never narc'd on nobody!
Another lowered compression build
Also, 500 for a goal is all good and dandy, but for a purely street, daily driven car, it's kind of overkill. You realistically won't be using all of that on the street, ever. A smaller power goal, along with a smaller turbo (and higher base compression) will give you a much more pleasurable driving experience.
Old May 18, 2015 | 01:31 PM
KevinEF7's Avatar
Why bottleneck a large plenum intake manifold, ported head and lots of valvetrain goodness with a stock throttle body?
Old May 19, 2015 | 12:05 AM
m0sad's Avatar
The nozzle is the biggest one.
Im using all that power, just not all the time.
I have a profec b, for low/high boost.
And "Boost-by-gear" replacing them with a switch (:
About the throttle, you are right, but for now, thats good enough.
The sob b18 makes power !
Now you guys can direct me from ur experience how much psi will i need to achieve 500-550?
Old May 19, 2015 | 08:08 AM
Stopsign32v's Avatar
Loved
Throttle body size with a setup to where the air is being PUSHED in is much less important than a setup to where the air is being PULLED in.
However a good rule is to match your throttle body size to your intake pipe size and/or intake manifold size.
Old May 19, 2015 | 08:11 AM
Loved
How should anyone know? Also what does it matter? I'll never understand the questions like "How much boost is too much for my motor?" and "How much boost will I need to make XXX power?"
Old May 19, 2015 | 08:14 AM
LightningTeg's Avatar
Community Builder
GT30R Comes to mind for this power goal and application
But 500 is definitely usable from 3rd on with a well setup car and the right tire (R888)
Stock throttle body is fine.
Old May 22, 2015 | 04:45 AM
m0sad's Avatar
first of all you need to understand what i wrote, then Q me.
i do not need to know what is the safe boost or what not.
I want to know from other's experience how much boost I need with my setup to get there.. a simple assessment 5psi - 30psi
hope i made my self more clear to you.
thx man
Old May 22, 2015 | 05:29 AM
Community Builder
thx man
Id guess 25lbs to make that.
Old May 22, 2015 | 07:33 AM
TheShodan's Avatar
Moderator
Depending upon tuning style, I'd similarly agree. About 19-22psi to accomplish that with a larger mid-frame like a Precision 62mm
Old May 22, 2015 | 10:03 AM
Charlie Moua's Avatar
for street go with cc stage 4 6 puck... will be easier and hold the power just fine for your application.
also I have a 2 close friends who have issues with their stage 5 cluches.... weird...
500whp... smaller turbo is my vote
I have gt3540 on my 1.8 gsr and get full boost at 4800-5000rpms and at times i still feel a little handicapped on the streets. lol
Old May 23, 2015 | 12:30 PM
m0sad's Avatar
My setup is ok.
Had no issues with the clutch, really good for the street.
24psi is my limit.
So i guess I'll be fine.
On a good road i hope to grip the 3rd on 21psi.
Any of you had experience with that kind of power with the OEM lsd ?
d16a6biuld
36
Oct 11, 2010 07:20 AM
victor.ek4
189
Dec 4, 2009 02:36 PM
krkline2gdsm
17
Dec 11, 2006 07:54 PM
-Whitey-
13
Jun 29, 2006 10:57 PM
BluGen2
13
Mar 24, 2004 08:28 AM
