B18B1 bored to the maxx???
Old Apr 6, 2011 | 06:00 PM
blue91EF's Avatar
Icon3 B18B1 bored to the maxx???
anyone gone 60 over on this motor?
whats the best setup for a turbo build? pistons im aware of but im gonna go all motor until o can afford the turbo setup
what upgrades should i do that arnt gonna be worthless once i go turbo??
Old Apr 6, 2011 | 06:14 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: B18B1 bored to the maxx???
60 thou is just 1.524mm, thats simple
Old Apr 7, 2011 | 06:33 AM
guy_from_nerk's Avatar
You don't build an all motor setup, then turn around and slap boost to it. You build them completely different, just a heads up.
Old Apr 7, 2011 | 05:52 PM
blue91EF's Avatar
im aware of this. im jsut wondering if gthere was maybe a crankshaft that would work both ways or valves. ect.. small things.
pistons of course wont work both ways. im just wondering if 85mm low compression is gonna work without blowing up. not NA obviously that would be a stone in the road.
Old Apr 7, 2011 | 08:26 PM
wantboost's Avatar
Who is Mr Robot?
id be afraid about headgasket sealing with that big of a bore
Old Apr 8, 2011 | 11:34 AM
blue91EF's Avatar
yeas ive been told 20 over is prolly the best idea.
but j/w if anyone has done 40 or 60 over?
Old Apr 8, 2011 | 12:21 PM
Are you going to sleeve the motor? If not then hell no I would not put 85mm pistons in a stock block. Hell I wouldn't put 85mm pistons in regardless, I bought a set thinking that "bigger is better", ended up finding out that having too big of piston can be a bad thing, just like wantboost said "headgasket sealing issues" will arise according to most engine builders I talked to. Why not just stick with stock bore? Boost is the equalizer, not to mention if you blow it up you still have room left for rebuilds... If I could go back and do some things differently with my build, staying stock bore would be 1 of the things I would change instead of going 84mm. I would've just had sleeves put in the block, but kept the bore 81.
.040 comes out to what .5mm over bore? Alot of people go 81.5 on stock sleeves, idk to many people that go beyond that without sleeving the engine.
Khoa_DC2
Apr 10, 2012 10:29 AM
ballinboosi
Apr 7, 2011 10:15 AM
7rrivera7
May 28, 2007 02:38 PM
jikespingleton
Dec 1, 2006 11:27 PM
inzane
Jul 27, 2005 09:07 PM
