B18B Civic ......How do you like it?
Old Nov 28, 2001 | 01:41 PM
eddie1681's Avatar
New User
Default B18B Civic ......How do you like it?
Hi
I have been thinking about the H22A or the B18B Turbo swap.
Can someone with the B18B turbo EG tell me how much that like the set-up? I am having a hard time making up my mind about the 2 swaps.
Thanks
Old Nov 28, 2001 | 01:44 PM
ForcedAccord's Avatar
Texas B*tch!
Default Re: B18B Civic ......How do you like it? (b20z)
H22a, me gusta mucho.
Old Nov 28, 2001 | 01:54 PM
dbman96's Avatar
New User
Default Re: B18B Civic ......How do you like it? (ForcedAccord)
I would think twice about the H22a in a civic. The engine doesn't fit particularly well and will upset the weight balance of your car among other things.
Old Nov 28, 2001 | 02:03 PM
DIRep972's Avatar
Smarter than you
B18B with turbo in a hatch is just amazing.. 12's easily on 8psi stock motor..
and the potential is amazing.. power is so easy to come by once your turbo..
IM JBsadler, he may be selling his freak(266whp @8psi) B18B Drag3 setup in his hatch right now if he cannot find another hatch to swap it into..
[Modified by DIRep972, 11:05 PM 11/28/2001]
Old Nov 28, 2001 | 02:28 PM
Jet Phi's Avatar
i rather be hearin sweet sound of B16B turboed than h22....
Old Nov 28, 2001 | 02:31 PM
Rob03Pro5's Avatar
Default Re: B18B Civic ......How do you like it? (ElectronBlueSi)
I'd take a B18 motor over an H22 anyday. Less complications and tons of people have done it.. so you have somewhere to go for answers. Now, if money was no obstacle, the H22A will probably be better.. but I'm talking about changing everything out.. the only benefit would be a bigger block (sleeves).
Old Nov 29, 2001 | 10:39 PM
eddie1681's Avatar
New User
B18B with 8psi can do 12's? How much HP is that?
Oh yes I am going to run an T04B turbo with that, is that good or too much lag?
I think i will do that, what's the max psi can the stock block hold safely?
Thanks
Old Nov 29, 2001 | 10:56 PM
DIRep972's Avatar
Smarter than you
you can run 12's in a hatch with about 225whp.. assuming you can drive
a stock LS motor can handle 10-11psi easily with the right fuel and some people have taken it even further with tuning..
no a T04B is perfect for the LS, even the T04E will be good.. dont worry about lag, its not much..
Old Nov 29, 2001 | 11:19 PM
Slain's Avatar
Default Re: B18B Civic ......How do you like it? (DIRep972)
i'd take the b18b with all that power you are gonna be making might as well save a tad more and get some LSD ( quaife,kaaz) to put that power to the ground
Old Nov 30, 2001 | 12:23 AM
turbocoupe's Avatar
Default Re: B18B Civic ......How do you like it? (Slain)
b18b for chure vato! H22 a weight issue and a mounting issue. more BS to deal with. . .but it's up too joO!
p.s. I'm drunk.
Old Dec 1, 2001 | 03:11 PM
Regular Series's Avatar
Default Re: B18B Civic ......How do you like it? (turbocoupe)
B18B, I'd think. All of the other guys are right on...the H22A is a more powerful motor (stock), but is H U G E compared do your current motor. Not only does that mean shoehorning (and possibly having to give up P/S and/or A/C to do so ) but the weight gain in the nose would be disastrous from a handling perspective. Bear in mind that a B18B1 will pull the Integra (which is almost 200 lbs heavier than your Civic) to 60 in 7.6 seconds, and down the 1320 in 15.5-16.0. A turbo B18B would have a negligble weight gain problem, so you wouldn't have to beef up the chassis and suspension quite as much...although it is still advisable, considering the power gain.
Old Dec 2, 2001 | 05:14 PM
jbsadler's Avatar
New User
Default Re: B18B Civic ......How do you like it? (rawdigga)
There is no question about it.....LS/Turbo is the way to go....plus LS motors cost half the price of GSR motors...
Old Dec 2, 2001 | 05:23 PM
Tapp's Avatar
New User
I loved my b18b, till i went ls vtec... then I loved it more . now I want to rev higher and I'm going b18c.
Old Dec 2, 2001 | 07:27 PM
DA666's Avatar
Default Re: B18B Civic ......How do you like it? (Tapp)
b18a/b is the way to go...the torque numbers stay close to the hp numbers when adding a lil dose of boost.
the gsr, or any vtec for that matter, when turboed, the torque numbers cant keep up the the hp numbers like the ls. imo
Old Dec 2, 2001 | 07:32 PM
D-Man's Avatar
Default Re: B18B Civic ......How do you like it? (T3T4DA6)
H22 all the way,way more power and even more impressive when u open the Hood to show it off,not too many H22 civics running around as compared to B18s
hqr180
26
Dec 29, 2004 12:10 PM
Turbo Sleepers
Oct 19, 2004 10:46 AM
EM2Civic
Jun 11, 2004 08:05 AM
Rev-Olution
Jul 1, 2003 03:58 AM
djay86
Apr 10, 2002 04:54 PM
