B18a/b + crank
Old Mar 10, 2005 | 09:13 PM
Si Shane's Avatar
Default B18a/b + crank
Double the questions for clarification
Do the b18a and b blocks and cranks interchange? Thanks
Does it matter if my crank came from an a and the block is a b
And with an oem headgasket and stock b16a2 head, what kind of compression change am i looking at when selecting a piston that says something like 9:1.
If the pistons for the LS motor say 9:1, what will the compression be around with a stock headgasket and a b16 head?
Old Mar 11, 2005 | 04:14 AM
NJIN BUILDR's Avatar
Default Re: B18a/b + crank (Si Shane)
B18a&b are the same crank.It doesn't matter which engine the crank came from.Try a compression calculator like this. http://www.c-speedracing.com/h...c.php
Glenn
EM1PILOT22
Oct 20, 2009 10:49 AM
civiconfire
Oct 31, 2007 12:44 PM
viciousvisionslarry
Dec 7, 2006 09:08 PM
EGkid
26
Oct 25, 2004 10:08 AM
