b18 crank in a b16?
Old Nov 19, 2002 | 04:40 PM
avividmemory's Avatar
Default b18 crank in a b16?
got a b16 sleeved to 83mm, and i want to put a b18b or b18c1 crank in it to increase the displacement...but im not sure if my b16 crower rods will work with a different crank...
basically i dont know if the size of the crank would affect that situation...let me know
Old Nov 19, 2002 | 04:45 PM
InfamousRS's Avatar
Default Re: b18 crank in a b16? (SpoolinLS)
You wont be able to run your crower rods if you use the LS or GSR/ITR crank....you will have to use way shorter rods (not sure which ones, custom maybe) which will pretty much put your R/S ratio in the *******...it will make for a very unstable motor.
You could send your block to GEM and have them instal sleeves and a deck plate to acheive a better r/s raito...
Old Nov 19, 2002 | 04:49 PM
Default Re: b18 crank in a b16? (InfamousRS)
its already sleeved by ge actually...i just wasnt sure if those cranks would work...no big deal she'll still be nice even with a b16 crank
Old Nov 19, 2002 | 04:51 PM
InfamousRS's Avatar
man, to bad its to late to get the deck plat...
You would beable to make a 2.0 liter b16
Old Nov 19, 2002 | 04:55 PM
not to sound stupid, but whats a deck plate do?
Old Nov 19, 2002 | 05:14 PM
The_Head's Avatar
It's a plate that goes between the head and the block. It allows you to increase the stroke of the engine.
Old Nov 19, 2002 | 05:16 PM
Default Re: b18 crank in a b16? (xThexHeadx)
so whats to stop me from getting one now, why is it too late?
Old Nov 19, 2002 | 09:59 PM
InfamousRS's Avatar
The deck plate is a peice of thick peice of metal that is cut (or machined) to the exact shape of your deck (top of block), when you used a deck plate you have to have sleeves that are taller to accomidate the plate.
Old Nov 19, 2002 | 10:01 PM
its all beginning to make sense to me now hehe...thanks a bunch
Old Nov 19, 2002 | 10:09 PM
FFgaeson's Avatar
by boring out your motor you increased the displacement... and as for deck plates... im not gonna comment on that.. . just hope you dont plan on driving your car much...
Spec R_GSR
Jan 15, 2007 11:48 AM
91crxturbo
Jun 8, 2006 09:37 PM
turbocrx2.1
Oct 2, 2005 03:59 PM
UNKNOWN_MEMBER
Apr 18, 2005 08:14 AM
EgGriff
Mar 12, 2005 08:41 AM
