B18 bosoted help
Old Dec 24, 2012 | 06:50 PM
boosted_civiceg's Avatar
Default B18 bosoted help
i dunno how big of a turbo to run on my b18... i have 9.0-1 comp je pistons. manley h beam rods. and all arp bolts.. fully built head with bcs3 cams springs and retainers... need help on a turbo... and i still have stock sleeves
Old Dec 24, 2012 | 06:58 PM
boosted_D's Avatar
Default Re: B18 bosoted help
http://www.prolineracing.net/index.p...chk=1&Itemid=4
Old Dec 24, 2012 | 07:03 PM
justYncredible's Avatar
It's wU to the sOLdiEr!
You should have made the decision on a turbo before you did all of that work. Those cams you have may be an issue, since there stage 3 I assume.
Op
The information you posted has absoultely no direction to it. The size of the turbo will depend on how much hp you would like and where you want it to shine at. We here can only suggest but YOU have to do some homework as in finding out how to read compressor maps.
The holidays are here and people have to much free time...
Old Dec 24, 2012 | 07:12 PM
boosted_D's Avatar
Clearly you didn't check my link, this is the perfect turbo for him, no matter what.
Old Dec 24, 2012 | 08:35 PM
diesel718's Avatar
Op
those cams are named 3's but its actually buddy clubs stage 1 in reality...theyre label as buudy club 3, 4 , and 5's; instead of stage 1, 2 and 3...
as far as what turbo to use, it depends. do you wanna spool faster or spool at a later rpm? how much psi can your motor with stand? how much psi do you plan on running? is your fuel setup able to push the power you want?
thats just a few ideas you wanna think about before just putting something on that wont give you the power you want. i would ask a reputable tuning shop or one of the many turbo companies about what your goal is.
Old Dec 24, 2012 | 08:37 PM
diesel718's Avatar
and remember, if youre trying to run big boost, keep in the back of your head that you have stock sleeves!
Old Dec 24, 2012 | 09:53 PM
sorry i wasnt directing that comment towards you
it was to the OP
Old Dec 24, 2012 | 09:57 PM
um, since when did you use psi to determine power?
PSI IS MEANINGLESS!!!
5lbs on x turbo is different on another!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!
crxdonwon
Dec 3, 2007 05:44 AM
92_red_teg
May 1, 2004 11:53 AM
slowww b18b1
Apr 23, 2004 12:24 PM
92JDMSiR
Apr 24, 2003 08:30 PM
Hispeed
Jun 18, 2001 11:48 AM
