B16's with GT28RS dyno sheets???
Old Aug 26, 2006 | 05:26 AM
mrx's Avatar
mrx
Default B16's with GT28RS dyno sheets???
Hi,
i'am looking for some B16 GT28RS Dyno sheets.
i did allready searched, but more dyno sheets i found was on B18 engines.
if you know some B16's with a GT28RS turbo please post everything you have ... links/dynosheets/spoolup times etc...
Hope to get some real good info's about this turbo on a B16...
Thanks
Old Aug 26, 2006 | 06:03 AM
rmcdaniels's Avatar
Default Re: B16's with GT28RS dyno sheets??? (mrx)
Darton-sleeved, RLZ-built, B16 -w- 8.4:1 custom Wiseco pistons, 23 PSI of boost. GT28RS with ATP .82-AR T3-flange turbine housing. Clutch was slipping at the top of the run, later we made 380 with it, but I didn't save that chart. This dyno also seems to read 20 or so WHP too low, mostly use it for tuning. Lovefab SST manifold -w- Lovefab 3" downpipe and 3" TR Turbo exhaust. It spooled almost instantly from about anywhere. Tuned by JDogg with an AEM EMS. Car was daily driven for years, full interior EM1 -w- AC, drag raced weekly (usually ran about a 12.0 at around 119 MPH, yeah, I suck at drag racing), ran it on road courses several times, parted it out to go all motor, motor is still running strong in another guy's car, same story for turbo and manifold:
Old Aug 26, 2006 | 06:22 AM
mrx's Avatar
mrx
I found that dynosheet a few month ago, but thanks for the reply.
i have one short question left. From the dynosheet i guess full boost (23psi) are build at aprox. 5000rpm.
can you aprox. tell me at which rpm do the turbo begin to spool (makes significant over atmosphere pressore i.e. 2psi boost) and at which rpm did it makes aprox. 14psi?
hope for some more inputs...
Thanks
Old Aug 26, 2006 | 07:47 AM
rmcdaniels's Avatar
Yes, full boost was a bit before 5000 RPM, and it started making boost from wherever you mashed the gas, even down around 2500 RPM. I think 14-15 PSI was made around 3500-4000, although it built boost so fast it was hard to tell. Your setup will vary however, as this was a fairly low compression setup. Higher compression setups will behave differently.
Old Mar 17, 2007 | 06:56 AM
aalb1's Avatar
Default Re: B16's with GT28RS dyno sheets??? (rmcdaniels)
Here's mine...
Stock block
Old Mar 17, 2007 | 08:36 PM
batboyvaj's Avatar
how much boost are you running
Old Mar 18, 2007 | 10:40 AM
tegdude227's Avatar
bump for more info gotta be one of my fav turbos whats the most people have seen outta thease with the big hot side ? also what manifold does everybody run
FATBOYeg6
Jun 16, 2007 07:03 AM
spoolingEF
May 1, 2006 04:19 AM
self_made
Mar 14, 2006 02:27 PM
volkdlr
12
Jul 8, 2005 09:08 PM
The ZC
Jan 5, 2005 09:41 PM
