b16a3 block build. Need some inputs. <-----
I have the block and eagle rods right now. I need some input on what else to get for my build. The block i have is bare nothing on it, but it's a super clean block. What other misc. things would i need to make it a complete shortblock also?
Block: B16a3 *
Rods: Eagle H-Beam Rods *
Pistons: Arias/Wiseco? or any other suggestions? Along the lines of 9:1 compression. I heard that SRP's are bad because they expand alot during high heat?
b16 or b17 crankshaft
b16 oil pump/ water pump.
ACL Bearings Kit.
what else am i missing? being that i am a noob to the b-series.
the goal is 300whp.
Block: B16a3 *
ACL Bearings Kit.
the goal is 300whp.
yes i've heard good things of CP too doing research here. Those are pretty much my top 3 Wiseco/CP/Arias. Yeah, I thought about sleeving too. Just don't think i could come up with the cash.
i have a 9to1 compression b16 with eagle rods acl bearings and je pistons. i recomend going with 9:5:1 compression. O BTW when the car is cold the pistons make a lot of noise. I Like JE pistons but w.e you want should be fine just dont drop your conpression too much its not neccesary.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92redhatch »</TD></TR><TR><TD CLASS="quote">i have a 9to1 compression b16 with eagle rods acl bearings and je pistons. i recomend going with 9:5:1 compression. O BTW when the car is cold the pistons make a lot of noise. I Like JE pistons but w.e you want should be fine just dont drop your conpression too much its not neccesary.</TD></TR></TABLE>
You really think he's going to notice a .5:1 difference in compression? Me neither. Your pistons if they're a "9:1" shelf piston are probably more like 8.8:1 or lower, and I bet you'd never even notice the difference between them and some real 9.5:1 pistons. My buddy bought a new B16 motor that was advertised as having wiseco 9:1 pistons, but it had Wiseco's 9:1 pistons for B18C motors and his motor was actually at 7.7:1 compression, and he said didn't even really notice the difference in low end between that and his other B16, which was a stock JDM block with a .080" cometic HG for about 9.2:1 compression, he thought they were both 9:1 and didn't really feel much.
Inspector Gadget
Northwest (Sales)
Aug 29, 2008 01:41 PM
BoostedGSRBubble
Feb 15, 2003 09:38 PM
