B16A2 or B18B
Old Oct 13, 2001 | 12:32 PM
H22CIVIC's Avatar
New User
Default B16A2 or B18B
What would you guys rather turbo, SIR or an LS motor?
Old Oct 13, 2001 | 12:47 PM
immortal's Avatar
Banned
Default Re: B16A2 or B18B (H22CIVIC)
LS
no replacement for displacement applies to turbocharged cars too
Old Oct 13, 2001 | 01:24 PM
WykidEH's Avatar
go w/the b18b, the tr. at the low end is badass!
Old Oct 14, 2001 | 03:14 PM
H22CIVIC's Avatar
New User
Default Re: B16A2 or B18B (WykidEG6)
Does anyone here have an SIR motor with boost here? Does anyone think I should do an SIR over an LS?
Old Oct 14, 2001 | 06:36 PM
whiteb16a's Avatar
New User
i would go with the b16 .if you port and polish your head you can lower the compression a bit ,then with the shorter stroke you can get higher rpms,which can help you spool up faster .i have a sir motor that im going to turbo this christmas.my freind in his si ,port and polish his head and put on a revhard stage 3 and he runs a good high 12 (12.81@??mph)good luck with what you choose,....
Old Oct 14, 2001 | 07:48 PM
Speedz's Avatar
Default Re: B16A2 or B18B (whiteb16a)
LS motor. if you already have it.. great, spend all ur money on building it and turboing it.. if u dont its still cheaper than the b16a and you can still have more money left over to build it compaired to the b16a
Old Oct 14, 2001 | 08:49 PM
PureTeg420's Avatar
exactly how does having more rpms available spool up a turbo faster? b18b all the way for turbo!!
Old Oct 14, 2001 | 09:31 PM
whiteb16a's Avatar
New User
Default Re: B16A2 or B18B (PureTeg420)
it helps buy ,....most turbos dont kick in till about 3500 4000rpm.so if you can keep you rpms up when you shift gears you rpms wont go below 3500 or so .it mainly helps in 1 and 2nd gears .this also helps if you have ecu with no rev limiter .so you can rev high , the next gear will start out at a higher rpm,thus keeping your boost up and avoiding lag .if you have a ls or even ls/vtec you wont be able to rev over 7000 rpm.both r good choices im going with the b16 .the ls is good because of the low compresion so you can turn up the boost .so either will work ,.......
b18swapef
11
Apr 23, 2009 10:49 PM
kliebertfamily
Jun 9, 2006 07:40 AM
RaceCarRyne
May 7, 2006 12:25 AM
hahahahhah
22
Jan 14, 2003 06:21 AM
curiousgpnoy
89
Dec 19, 2002 06:41 PM
