B16A stroker turbo
Old Jan 23, 2008 | 05:18 PM
x-s-i-v's Avatar
Default B16A stroker turbo
ive just finshed my turbo build on my b16a intergra.
old
new
im currently running a stock b16a1
with
t3/t4 turbo
38mm race pro gate
stanless headers
3" stanless steel exhuast off turbo
2.5" intercooler piping
big alloy intake and tb
walbro fule pump, reg etc
link plus engin managment
New motor being assembled
b16a block
darton mid sleeves max 85mm
je spr pistons 81.5
eagle rods
eagle stroker crank 1740cc
abes oil pump
acl race bering
ported b16a head
type r cams
valve springs ti retaners etc
adjustable cam gears
what im wanting to know is would it be worth going right out the the 84-85mm pistons to get the 1.9l b16a
looking for around 500hp.
will be looking at changing my turbo. maby a gt35 or gt30 depending on my needs for the motor.
has any one got dino graph for a stroked b16a. im finding it hard searching for anything.
any input would be good
Old Jan 23, 2008 | 05:28 PM
b20vtech's Avatar
Default Re: B16A stroker turbo (x-s-i-v)
everything looks good except the "SS manifold" isn't that the Ebay manifold?
Old Jan 23, 2008 | 05:58 PM
HondaCivicSiR1's Avatar
Default Re: B16A stroker turbo (b20vtech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vtech &raquo;</TD></TR><TR><TD CLASS="quote">everything looks good except the "SS manifold" isn't that the Ebay manifold?</TD></TR></TABLE>yes it and why is there a hose clamp on the wastegate?
Old Jan 23, 2008 | 06:03 PM
Teglove2's Avatar
Why would you spend money on a great bottom end and head package then throw some garbage manifold on it? I dont get it but good luck....it'll be fun until you hear an exhaust leak.
Old Jan 23, 2008 | 06:08 PM
philafelman's Avatar
Default Re: (Teglove2)
it kinda looks beefier than an "ebay" manifold, i have one chillin in my garage, and i dont remember it having welds in the middle, but it could be...i dunno. what are the specs on the t3/t4?
Old Jan 23, 2008 | 08:14 PM
Schister66's Avatar
Man U FTW
stout bottom end and an Ebay manifold.....that's like buying a Ferrari, but letting it sit out in the snow and rain because you cant afford a garage....
Old Jan 23, 2008 | 09:15 PM
japanjay's Avatar
* B A N N E D *
^^^^ LMAO. Hit the nail on the head.
Old Jan 23, 2008 | 09:41 PM
American.Graffiti's Avatar
Default Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">stout bottom end and an Ebay manifold.....that's like buying a Ferrari, but letting it sit out in the snow and rain because you cant afford a garage....</TD></TR></TABLE>
now thats funny.
Old Jan 23, 2008 | 11:55 PM
WrongWD's Avatar
that's not an ebay manifold, that's a spark racing manifold
Old Jan 24, 2008 | 01:47 AM
140sx's Avatar
Id stay with the smaller boar just incase something was to happen you can just go over.
Old Jan 24, 2008 | 03:50 AM
nitroice40's Avatar
Default Re: (140sx)
I was running almost the same setup.
b16 block Mid84mm
Je Pistons
eagle stroker kit
b16 head
some cams I know nothing about (was told were skunk 2)
62-1 turbo
made 612whp at 28psi.
Old Jan 24, 2008 | 07:32 AM
Schister66's Avatar
Man U FTW
Default Re: (WrongWD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WrongWD &raquo;</TD></TR><TR><TD CLASS="quote">that's not an ebay manifold, that's a spark racing manifold</TD></TR></TABLE>
Ok good...the name change will make it a "quality" manifold. Fact is, its the same POS as Ebay
Old Jan 24, 2008 | 09:29 AM
WrongWD's Avatar
Ok good...the name change will make it a "quality" manifold. Fact is, its the same POS as Ebay</TD></TR></TABLE>
spark racing designed the original that ssac copied. but i'm sure you knew that. i guess they just charged $500 for a handmade manifold that was the same as the one they sold on ebay.
Old Jan 24, 2008 | 09:54 AM
dc2____R's Avatar
how much power are u looking too make? If its something high horsepower id look into a different crank like oem cause its proven itself multiple times
Old Jan 24, 2008 | 04:48 PM
x-s-i-v's Avatar
yeah the mainfold is custom made.
not a cheep ebay one lol.
i think the pics dont give it justuce
it will flow alot better then my old blox one.
car was not looking to good, nor was the mainfold, nice and shiny now
will this mainfold support 500hp with the right turbo or should i look for a new one
the wastgate is a vband type. it a good brand over in new zealand
the t3/t4 turbo is ar.50 it will do the job befor i upgrade grade
not sure the size of turbo i will need to produce around 500hp
im looking for about 500hp+ on c16 and 300 on 95 pump gas
im sure the motor will hold up im just not sure about my cable ys1
nice dino graph. must go nuts down the strip.
Modified by x-s-i-v at 6:12 PM 1/24/2008
Old Jan 24, 2008 | 05:24 PM
*Boostwerks*'s Avatar
Damn, you just wasted some $. Stroker B16 = B18.
Old Jan 25, 2008 | 04:47 PM
Teglove2's Avatar
That chart of the stroker b16 with 62-1 looks like my journal bearing gt4202 graph....
Garage786
Jul 9, 2012 07:14 AM
x-s-i-v
Oct 15, 2008 02:18 PM
Boring
Apr 7, 2005 07:00 PM
1JDMDOMINICAN
Mar 3, 2004 05:12 AM
