B16 Supercharged BLOWN
Old Aug 13, 2003 | 05:09 PM
motore's Avatar
Default B16 Supercharged BLOWN
CRX B16a Supercharged at 11lbs.
Motor blew at a Solo 2 event
mmmmmmmmm.........
What motor next ? ? ? ........................
Old Aug 13, 2003 | 05:14 PM
gritsak's Avatar
Default Re: B16 Supercharged BLOWN (motore)
wow...thats not pretty
Old Aug 13, 2003 | 05:16 PM
CRVRX's Avatar
You need to address those lean conditons on any motor you go with . I would go with a 1.8L at least , build the bottom end and stay around 10-1 compresion.
You will need to bring those intake temps down , or lower the boost and run a little less timming.
What kind of management are you running ?
Old Aug 13, 2003 | 05:25 PM
Adi Radoncic's Avatar
On Fire!
I personally don't think the motor blew up because of a lean condition but timing or detonation could have been what killed that poor thing.
I would just get a gsr block with compression somewhere in the mid to upper 9's and rebuild that head if I had to choose a new powerplant...
Adi
Old Aug 13, 2003 | 07:03 PM
CRVRX's Avatar
Default Re: B16 Supercharged BLOWN (newgsr)
Most of the time detonation is caused by bean lean , and too much timming.
Old Aug 13, 2003 | 08:53 PM
The Brown Kid's Avatar
Default Re: B16 Supercharged BLOWN (CRVRX)
Looks like it was a little warm in there.
Old Aug 13, 2003 | 10:15 PM
lazerus's Avatar
Default Re: B16 Supercharged BLOWN (The Brown Kid)
so are those holy pistons now?
Old Aug 13, 2003 | 11:19 PM
89 JDM CRX's Avatar
Default Re: B16 Supercharged BLOWN (lazerus)
hehe that's my buddys car , we pulled it apart this morning to find that lovely mess
Old Aug 14, 2003 | 09:26 AM
-Trinitron-'s Avatar
I haven't seen anything that ugly since sprayed an open bottle on a JRSC d16!
Old Aug 14, 2003 | 09:31 AM
DaveF's Avatar
Default Re: (-TRINiTRON-)
time for the jbweld
Old Aug 14, 2003 | 09:50 AM
redlinegsr's Avatar
Default Re: (2.2Lcivic)
trashed ouch good luck with the new build
Old Aug 14, 2003 | 10:01 AM
MachAF's Avatar
what was your fuel setup?
Old Aug 14, 2003 | 10:05 AM
MADEINIRAQ's Avatar
Default Re: B16 Supercharged BLOWN (MachAF)
what he said..
what is your setup... JRSC?
Old Aug 14, 2003 | 12:58 PM
luckypon7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazerus &raquo;</TD></TR><TR><TD CLASS="quote">so are those holy pistons now?</TD></TR></TABLE>
that was funny **** man...
Old Aug 14, 2003 | 02:18 PM
hulkhb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.2Lcivic &raquo;</TD></TR><TR><TD CLASS="quote">time for the jbweld </TD></TR></TABLE>
better have another
Old Aug 14, 2003 | 02:44 PM
FULLTHROTTLE's Avatar
Default Re: (hulkhb)
I dont think that had anything to do with fuel management or temps. It looks like a dropped vavle or a overrevved engine floating the valve. All the damage is form collision. Auto cross events tend to have many high revving shifts so my money says it was downshifted a tad too early. Sorry bout the motor but now oyu have an excuse to spend more money WEEEE!
Old Aug 14, 2003 | 03:39 PM
ATS*Mark's Avatar
OG triple OG
Default Re: (FULLTHROTTLE)
i dont know what you guys are talkin about...
its still good
Old Aug 14, 2003 | 05:05 PM
AlphaKennyWun's Avatar
Default Re: (TURSpoonEK)
Fullthrottle was right. everyone thought it was a leaned out condition but thats a dropped valve. no doubt. overrrrrrrrev!!
Old Aug 14, 2003 | 05:49 PM
MachAF's Avatar
Default Re: (S03Burner)
No doubt that valve dropped.
Looks like piston number one has some melting or something.
Not sure why it'd be white unless something got lean.
Old Aug 15, 2003 | 05:55 AM
motore's Avatar
I broke everything on run #2
but I do admit in run #1 i did over rev the motor but after
I went a drive on the strrets for a bout 2 min not high revs.
Run #2 I gave it out of the hole after 2 turns a straight aaaaaand bang
Destroyed
Can run#1 drop and valve but yet continue to let me drive to run #2
there was 1 hour waiting period from run 1 to run 2
also that valve thats busted the valve retainer is broken in half.
any help is appreciated
thanx
Old Aug 15, 2003 | 09:02 AM
Default Re: (motore)
If you overrevved it the piston may have made slight contact with the valve cracking the retainer or knocking a keeper out. Then on the next run all hell broke loose (pardon the pun).
Old Aug 15, 2003 | 09:29 AM
BoostedsiR's Avatar
god damn bro good detonation just a lil too much lean I guess that throws the statement that superchargers are safe out the window
Old Aug 15, 2003 | 10:12 AM
glagola1's Avatar
Default Re: (BoostedsiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedsiR &raquo;</TD></TR><TR><TD CLASS="quote">god damn bro good detonation just a lil too much lean I guess that throws the statement that superchargers are safe out the window </TD></TR></TABLE>
It was OVER-REVVED.
Anyway, bummer. I'm guessing that with 11psi non-intercooled and B16 type static compression something was bound to happen anyway.
I bet it's nice autocrossing with a SC. I autocross with a small ball bearing turbo on my LS swapped hatch. It's a little hard to contol coming out of the corners when the boost comes on. It's not like my car needs any more reason to understeer.
Old Aug 20, 2003 | 03:54 PM
motore's Avatar
Default Re: (glagola1)
Question ???
GSR - ALL MOTOR
OR
B20Vtec - All MOTOR
any suggestions
Obviosly GSR will be cheaper
Old Aug 21, 2003 | 03:46 PM
motore's Avatar
any suggestions to above
