avcr question
Old Jun 1, 2002 | 10:55 PM
Aeka GSR's Avatar
New User
Default avcr question
Is it normal for the avcr to read like around .09 kg/cm2 of boost when the engine is off? Or is my stuff fucked up?
Old Jun 2, 2002 | 08:46 AM
Aeka GSR's Avatar
New User
Default Re: avcr question (Aeka GSR)
*bump*
Old Jun 2, 2002 | 11:02 AM
Quaalude's Avatar
it should read 0 kg/cm2....did u mount the pressure sensor perpendicular to the ground (barb end facing down)?....are u at sea level or higher elevation?
Old Jun 2, 2002 | 01:16 PM
Aeka GSR's Avatar
New User
Default Re: avcr question (Quaalude)
yeah its pointing straight down, im under 1000 feet above sea level
Old Jun 2, 2002 | 01:17 PM
PrecisionH23a's Avatar
what does it read while you are at idle?
Old Jun 2, 2002 | 01:21 PM
Aeka GSR's Avatar
New User
Default Re: avcr question (GudeH23a)
good question, ill be back in 5 mins
Old Jun 2, 2002 | 01:46 PM
Aeka GSR's Avatar
New User
-475 @ 760 RPM
Old Jun 2, 2002 | 06:50 PM
Aeka GSR's Avatar
New User
*bump*
Old Jun 3, 2002 | 09:21 AM
PyroVTEC's Avatar
New User
There's something wrong w/ your AVC-R's MAP sensor. Mine reads anywhere between -3mm/Hg and -22mm/Hg (depending on location and temps) when the motor's off. At hot idle, mine'll read in the mid -600mm/Hgs.
Old Jun 3, 2002 | 07:13 PM
Aeka GSR's Avatar
New User
Default Re: avcr question (PyroVTEC)
ahh geeze, well im going to remount it somewhere else and see what happens.
Old Jun 5, 2002 | 04:31 PM
Aeka GSR's Avatar
New User
[edit]cant delete post
[Modified by Aeka GSR, 5:32 PM 6/5/2002]
Old Jun 6, 2002 | 03:20 PM
mine reads about -350 to -400ish mmhg at idle also, it sounds like yours is working properly. does it fluctuate while you are under boost? also, it sounds like your rpms are a little low, are the rpms accurate with your rpm's on your stock tachometer? do you have all your map sensor lines ran correctly?
[Modified by GudeH23a, 7:21 PM 6/6/2002]
Old Jun 6, 2002 | 04:10 PM
LsTurbo91's Avatar
mine reads .02kg when its off and 500mm at idle.
1990si
Dec 11, 2006 10:01 AM
De_tour
Oct 26, 2006 02:34 AM
s1ngle
14
Apr 29, 2005 10:34 PM
Soccerking3000
12
Dec 26, 2004 08:16 PM
