autometer air/fuel ratio
Old Feb 12, 2007 | 06:44 AM
teddy_dc2's Avatar
Default autometer air/fuel ratio
all my gauges are autometer but my buddy says their air/fuel one is not as accurate. true? anyone with problems sugestions with autometer in general?
my buddy's phatom boost gauge reads about 3 psi higher than it is at any given time, and my sport comp boost reads fine until i beat on the car and it reads high vac at idle like around 22psi when suppose to be around 18psi, and when the car is turned off after warmed, it points to 1psi vac instead of mid zero.
Old Feb 12, 2007 | 06:49 AM
Turbogixxer's Avatar
Default Re: autometer air/fuel ratio (teddy_dc2)
Autometer gets the 02 signal from a narrowband sensor. The sensor is only slightly accurate at ~14.7 a/f.
You could program a wideband output (you would have to have a wideband sensor) to the guage and it will work better, but it is still a light show.
Old Feb 12, 2007 | 07:55 AM
Dunc's Avatar
BCICAN
Default Re: autometer air/fuel ratio (Turbogixxer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbogixxer &raquo;</TD></TR><TR><TD CLASS="quote">Autometer gets the 02 signal from a narrowband sensor. The sensor is only slightly accurate at ~14.7 a/f.
You could program a wideband output (you would have to have a wideband sensor) to the guage and it will work better, but it is still a light show.</TD></TR></TABLE>
Yep...unless you have the Autometer wideband kit.
JGUSH
Dec 8, 2013 04:57 PM
phearable
Jun 24, 2008 05:32 PM
KStuned
Oct 6, 2004 11:39 AM
mustbenu
Jan 27, 2004 11:21 PM
FBP Si 2000
Nov 28, 2002 11:46 AM
