ARP headstuds D16Y7 or D16Z6
Old Apr 19, 2005 | 06:23 PM
93turbo16's Avatar
Default ARP headstuds D16Y7 or D16Z6
Well I think I have the question answered but I wanted to make sure.
Block is a d16y7 and head is a d16z6. Which arp studs do I want?
Z6 part # is 208-4301
Y7 part # is 208-4305
I figured that you want the studs that correspond with the block. But I am just checking. Any help would be appreciated.
Old Apr 20, 2005 | 04:39 AM
93turbo16's Avatar
No one knows the answer? I ordered the D16Y bolts, so I guess I will just find out.
Old Apr 20, 2005 | 04:46 AM
Laserjock's Avatar
Default Re: (93turbo16)
please post your findings. i have a Y7 and a spare Z6 motor and would like to know too.
Old Apr 20, 2005 | 07:29 AM
ace42004's Avatar
Default Re: (Laserjock)
i had the same problem...but with a y8 block with z6 head, I was told to get the y8 arp headstuds
Old Apr 20, 2005 | 07:30 AM
93turbo16's Avatar
yea, I was told to get the head studs that correspond witht he block. So that is what I did.. hope this **** works.
Old Apr 20, 2005 | 07:34 AM
BauleyCivic's Avatar
Risky Business
I would have gone with Z6...
I know the Y7/Y8 headbolts are shorter than those of the Z6. I don't know if the threads in the block are shorter, or if the area where you bolt the head down is lower on the Y8 head. I'm pretty sure for Y8 mini-me's you need to use the Y8 head bolts, so I would have gotten the studs designed for the head.
Let me know if using the Y8 head studs works though
Old Apr 20, 2005 | 07:44 AM
93turbo16's Avatar
well if it is a problem, I will use my stock Z6 bolts I guess.
Old Apr 20, 2005 | 07:47 AM
Burke's Avatar
Banned
i too think you should have gone with the z6 studs. the z6's are longer cause where they bolt on the head they higher.
and please dont use stock headbolts, you know how our d's like to pop headgaskets
Old Apr 20, 2005 | 07:51 AM
93turbo16's Avatar
Default Re: (Burke)
This I konw, but they pop head gaskets with ARPs too. I will get another set if they are needed. Don't worry I am not going to be stupid about this. Just was told that it was the block that mattered. Maybe I can change my order. I just order both.
Old Apr 20, 2005 | 07:52 AM
Risky Business
Default Re: (Burke)
If they don't fit, see if you can do an exchange with the company you bought them from.
Old Apr 20, 2005 | 08:08 AM
93turbo16's Avatar
I just got off the phone with lightning motor sports. ANd I got them to hold the order until I figure it out.
He said to get him these numbers:
Depths of threads into the block
Depth before the threads start into the block
ANd thickness of the head.
If anyone could help, I would be greatful. Need to let them know asap.
Old Apr 20, 2005 | 08:20 AM
Risky Business
Well, do you have the setup put together? Try a Z6 head bolt and a Y7 head bolt and see which one works.
Old Apr 20, 2005 | 10:46 AM
93turbo16's Avatar
Nope, the head is on my car, and the block is at a shop. So I have neither. And I don't have the Y7 bolts. SO I am kinda shooting in the dark on this one. I can't believe no one has ever done this before.
No one seems to have an answer. ARP isn't sure, Earl doesn't know... my technical sources are dwindleing.
Old Apr 20, 2005 | 12:20 PM
nonvtecD's Avatar
Default Re: ARP headstuds D16Y7 or D16Z6 (93turbo16)
Bottom of bolt to deck of block: 2 3/8" (60mm) Threads start 13/16" down in block (21mm) Hope this helps. And to the person that said not to use stock headbolts, I re-torqued my B7 bolts 3 times and with 10 psi never had a HG issue, go figure.
Old Apr 20, 2005 | 12:29 PM
93turbo16's Avatar
Default Re: ARP headstuds D16Y7 or D16Z6 (nonvtecD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvtecD &raquo;</TD></TR><TR><TD CLASS="quote">Bottom of bolt to deck of block: 2 3/8" (60mm) Threads start 13/16" down in block (21mm) Hope this helps. And to the person that said not to use stock headbolts, I re-torqued my B7 bolts 3 times and with 10 psi never had a HG issue, go figure.</TD></TR></TABLE>
You are the man, thanks for doing that for me. Now, I think I need the thickness of a Z6 head. And I will be set.
Old Apr 20, 2005 | 12:59 PM
93turbo16's Avatar
well I called lightning motorsports with the specs and they compared the two studs. The difference is 3/4". So I ordered the Y7 because they are shorter. I think the main difference is on a Z6 the bolts start threading lower in the block. So hopefully this works out.
That for the measurements.
Old Apr 20, 2005 | 02:16 PM
Jaker's Avatar
I think you made the right choice with the 208-4305. I tried to use them (208-4305) on a D16A6 block with a D16Y7 head, and they were too short. This makes me think the D16A6/D16Z6 block has deeper holes in the block than the D16Y7/D16Y8 necessitating the longer bolts. I ended up using the D16Z6 bolts, but needed to add some extra washers on the 2 studs in the rear corners of the head. I added 3 washers (total 4) on those 2 studs because they were too long.
Just beware that you might be faced with the same requirement for extra washers. Also, if you do need extras, use the same flat ground hardened washers as come with the ARPs. I bought extras from ARP for $9 for 10, plus shipping.
Old Apr 20, 2005 | 07:24 PM
93turbo16's Avatar
thanks for the advice. I was actually looking into getting those. Because it seems like they don't mesh well between years, and I should be ready.
Old Apr 25, 2005 | 11:36 AM
GPNY's Avatar
I did a Y8 Block with Z6 head.
I used the Y8 Studs except for 1 Z6 stud at one of the corners (with 1 extra washer). 1 Y8 stud is about 1MM too short (opposite corner from where I put the Z6 stud) but I think I should be fine...
Old Mar 19, 2012 | 11:38 AM
andre.alves's Avatar
Hi Guys,
It´s right to use the ARP Studs cod 208-4305 in a d16z6 engine block with d16y8 head?
Thanks, Andre
Cruiser G
Sep 19, 2009 09:43 PM
turbo sol
Mar 2, 2006 11:57 AM
Maxpower350
Feb 25, 2006 11:57 AM
Jdm_Ek_Hatch
12
Sep 23, 2005 05:14 AM
Cruiser G
Feb 6, 2004 11:26 AM
