Was torquing down the head and one of the ARP head studs snapped and broke. Then used a extractor to remove it and the extractor bit now broke off as well....
WTF do i do??
WTF do i do??
**** !!! i've never heard this one before. Have you tried contacting ARP ? There customer service is excellent.
You must be improperly torquing the studs. Even if you did manage to break a stud at the correct torque, the studs should only be in the block finger tight, so theres no way you could have broken an extractor in the stud.
If the head is still on, pull the head and you should have some stud sticking out of the block to get some vise grips on or something. If its broken flush with the block, you will probably have to drill out the bolt completely straight and not mess up the threads, and go back in and tap the hole out to clean the threads.
Moderator in Chief
Youre not going to be able to drill out hardened steel in an aluminum block without F'ing it all up. If its broken below the deck take it to a machine shop. How much torque were you at when it broke?
the studs themselves get finger tight they dont get 83flbs as well lol
Yeah you had to of been doing something wrong here. Using arp moly lube the studs get torqued down in 3 steps. 25-50-80 final. The studs themselves DO NOT get torqued into the block at all. Just turn them in by hand till they bottom out or use an allen wrench and turn them in till they bottom out.
i'm just wondering how you broke one off. those studs are so strong that it would take a **** ton of pressure to snap one
Quote:
Bad stud maybe ??? Would you say its a possibility ?Originally Posted by racebum
ive had it where fod has gotten it to the threads whille rework had been done i always check the threads before i insert the studs . other wise the debris will make seem like you getting some where whille tighning but you just fighting crap in the threads.
true chasing the threads and blowing them out is a great thing to do
and snapping a stud in half takes more than a man can do im thinking lol
Quote:
with arp i really doubt it. those bolts are all xrayed - tested before leaving in a box. Originally Posted by rich7777
i just literally have never seen an arp headbolt or stud ever break in any engine. i'm not sure how many hundreds of ft/lb would even be required to do so but i would bet higher on the block threads stripping than the bolt/stud breaking
I saw someone else break one on another forum. Personally I have assembled so many motors and never had this problem. I would have to guess that the stud was either reused too many times or something was done wrong during tightening.
Quote:
x2....im curious as to how this happened its extremely rare..Originally Posted by sanman000719
pix??????
arp even stated to tq in 2 steps. tq in 3 steps or more gives inaccurate readings and cause alot of arp bolts to snap. ive seen it happen a couple times before
Quote:
Well you're doing it all wrong then and I've never seen it happen to anyone who's used them correctly.Originally Posted by v8killaz
Arp states a 3 step torque down process to a final value of 80ft/lbs. I called and spoke with a tech myself when I put my motor together. 25-50-80 is the easiest way to go about it. This is for B series studs. Not sure about D series honestly. Here you go Read #7
http://arpinstructions.com/instructions/208-4303.pdf
well on a diff forum arp tech said 2 steps. im sure it has to do with bolt stretchOriginally Posted by sc34dc4
Well you're doing it all wrong then and I've never seen it happen to anyone who's used them correctly.Arp states a 3 step torque down process to a final value of 80ft/lbs. I called and spoke with a tech myself when I put my motor together. 25-50-80 is the easiest way to go about it. This is for B series studs. Not sure about D series honestly. Here you go Read #7
and they odnt snap brand new usually after the tenth time they are tq's down
well to sum this up, ya f**ked up.
Quote:
think about how crazy what you're saying is. if you go 25-50-80 or if you go 35-80, both ways are 80lb. your statement basically is saying a lower torque number than the final will make the bolt snap.Originally Posted by v8killaz
Quote:
+1Originally Posted by 90ZCREX
at this point it doesnt matter what he did, it already broke.
might have to get that on a drill press and drill it out then timesert/helicoil it to retain the same thread size. good luck man
Quote:
ok here try to go to 80lb in 80 stepsOriginally Posted by racebum
the bolts will not be the same if you go straight to 80lb
if you have ever tq down studs then wait a couple hours and re-tq them. usually you can feel them being tightened more.
even honda says once they are tq down. re tq them because they change after that settle down
