ARP head studs or bust! Wtf?
Honestly every thread don't forget the head studs!
I know the head is torqued properly currently at 250hp. It's a Jdm 1st gen b16a engine internally stock. Headgasket has 30k and is going strong.
I want to run over 11lbs maybe 14lbs up to like 325whp on it tuned properly but all is said the head will lift.
I'm not pulling the head till it needs forged internals but want it to last I'm happy with that for sure
Not sure if my eBay t3/t4 is up to the challenge and am saving the better turbo for a b18c
I made 315whp on my stock GSR without touching ANYTHING internally and I never blew a HG. Having said that, they're not that hard to install...you pull the valvecover, remove the cam retaining caps, pick up the ***-end of the cam and lift it out from the timing belt, then unscrew the head studs and replace with ARP studs, torque and reassemble...3hr job including smoke breaks
Who is Mr Robot?
It's all in the tune with stock headstuds... ARP's give you more clamping force and therefore allow higher cylinder pressures. However the head will need to come off to install them and you will need a new headgasket
I'd use a 3 layer gasket for turbo and arp or even higher stage studs. If I go better studs and a turbo gasket the pistons won't handle over 340whp would they? It wouldn't be so much effort to leave the block in and swap low
Comp piston eagle rod arp bolts at the same time.
The same time in labor I could swap in my Gsr swap n shoot for 350+
Very lost on what to do / build next hoping for
Opinions :/
Stock super strong b16 it might take the 325whp as is good tune!
Opinions :/
im confused as to what your trying to get across. personally i have never heard of a turbo head gasket. as for head studs, there is only ARP and they dont do stages.
i just dont understand why some people want to push stock pistons so far passed there limit.
I don't know. I guess I should get in there and do it but am not ready for that step. It's a process. & it runs so damn good!
As for the studs! Td autowerkes has 1000+hp studs.
Thicker gasket = turbo gasket
Who is Mr Robot?
You can't really rate studs by power... golden eagle and ARP both make larger half inch studs but you have to have machine work done to the block and head to use them.
Just get ARPs and an OEM gasket and stop attention whoring
Who is Mr Robot?
And thicker gaskets are to lower compression, correct any milling done to block or head, or to potentially fix valve to piston clearances
Damn son.
OP... if you really wanted to get around taking everything apart to install studs, you could do it the lazy man's way (i.e. one stud at a time) to avoid replacing the headgasket. Granted, you still have to take the cams out and then re-time, but that's cheese.
I'd much rather do it right and install a fresh oem gasket, but that's just me.
Tempting some what! Thanks for the replies.
The gasket and studs were all replaced brand new in 08 has like 20-30k on it now no issues 250hp
Shooting for 325whp ish... Which is pretty big bhp for a stock b16a
So. Follow the removal procedure and take out 1 stud at a time... Which is take off cam
Covers cam caps cams... Then I can proceed to unscrew the stud then tighten the arp down? Tempting.... But work. But could be done.
If money isn't tight I'll drop forged Ross and pistons. Arp bolts and oem gasket.
Right track?
Btw I have a good tuner. But even he rec studs for over 310ish whp
Right track?
Right track?
Right track?
Ya and how many more bolts to drop in standard bore forged pistons and good
Balanced Rods/ rod bolts. Then add the 500hp turbo/intercooler n play?
I might as well leave this stock till I'm ready to
Do so or lazy man some assurance for more boost.
Hmmmm
Hmmmm
It works.
