ARP Head stud intall questions?
I tried searching, but came up with a variety of answers.
When installing the studs, do I
use a stud installer?
hand tight?
or do i try the backwards nut underneath a nut, and torque it down like that?
thanks
-erik
hand tight?
thanks
-erik
Double nut them! Hand tight doesn't work well (even thought it says it in instructions).
Hand tight - all the studs were at different heights, even with the moly lub provided.
Double nut - put one nut on one flare side up, then another nut flare side down, and tighten them against each other. use a use a wrench to seat them down all the way. Not real tight, but so they are seated all the way down.
[Modified by gtcali, 12:40 AM 12/19/2002]
sepulchral
Jun 11, 2006 02:12 PM
