ARP head stud install
Old Sep 9, 2005 | 01:46 PM
caster troy si's Avatar
Default ARP head stud install
I'm about to boost my LS motor and as a preventitive measure i bought some arp's.
Now, i just replaced my headgasket a month ago. So, i don't want to have to replace my HG again if the following or similar is a proven method to install the studs with out having to replace the HG.
Can i just take out all of the stock head bolts and then install the arp's, simple as that?(of course careful not to shift the head)
Can i take out one head bolt at a time and install the arp's to the first torque spec, then once all of the arp's are in, finish the torquing process?
Or has anyone tried these or other methods to installing new head studs without replacing the head gasket?
Old Sep 12, 2005 | 05:51 PM
JDMisGOOD's Avatar
Default Re: ARP head stud install (caster troy si)
Just replace the headgasket! Do it right or Don't do it at all!
Old Sep 12, 2005 | 06:00 PM
s2kdre's Avatar
Default Re: ARP head stud install (JDMisGOOD)
once u torque the head down it crushes the gasket, after u loosen the bolts the gasket is no good
Old Sep 12, 2005 | 06:18 PM
Muckman's Avatar
Moderator in Chief
If you want to do it half *** replace one at a time.
Old Sep 15, 2005 | 11:41 AM
you all have been an aid! thanks!
DelSol-B18
Sep 8, 2012 06:24 PM
twocross
Feb 23, 2011 03:07 PM
eg64u
Sep 11, 2007 08:15 AM
memorybox
Oct 21, 2006 09:02 PM
ludelvr
Mar 18, 2004 07:38 PM
