areomotive fuel pump install question
the aeromotive pump should be positioned pretty close to the tank, like within 3 feet or so, this helps with the "push/pull effect" i would NOT mount it in the engine bay. also it requires a "sump" to feed it, which is a sloped section in the back of your tank that looks like a ramp going downward, that has your feed and return fittings in it.
the feed comes from this and u generally put the return to the top of the tank. i generally put in the oem feed location... u dont put it back to the sump
bossman032
18
Jun 1, 2004 08:16 PM
