anyone using uberdata - 14b - d16z6 ?
Old Dec 20, 2004 | 01:00 AM
b.serious's Avatar
Default anyone using uberdata - 14b - d16z6 ?
well decided to go with the 14b. the wastegate is actually bad on the turbo .. will be running an external one.
juz wondering if the 14b wud die out at top end and wat quarter mile times are expected with this setup. a d16z6, 14b , uberdata with dsms 450cc
a bin file wud be of a lot of help.. also installation pictures of the 14b in a 95 civic
adios
Old Dec 20, 2004 | 06:04 AM
jobe_149's Avatar
Default Re: anyone using uberdata - 14b - d16z6 ? (soch4u)
the 14b is a GREAT turbo. This turbo pulls like a mother fckr...its a good size where it pulls down low and all the way to like 6500
Old Dec 20, 2004 | 07:59 AM
Burke's Avatar
Banned
Default Re: anyone using uberdata - 14b - d16z6 ? (jobe_149)
i had one and liked it on my y8. it was broken though, cracked turbine housing. i have a t25 on it right now and it is QUITE fun! although i did have to turn the boost up a couple psi to make it feel like the 14b
Old Dec 20, 2004 | 08:09 AM
Cray91's Avatar
I am confused. Did you put it on now, so you don't need te map. whatever.
Go look in mpfi.org, homemadeturbo.com, ect.
They all have .bin depositories that will help you out a little.
Old Dec 20, 2004 | 08:35 AM
b.serious's Avatar
naaa. i just bought one from the junkyard. got it all serviced with high pressure petrol. the turbo makes a very little grinding sound if u spin the wheel with ure fingers. the wheel spins veryyy free and dere are no signs of the fins rubbing against the housing.
ill be puttin this turbo on a z6 in a 95 civic. prob next week (vacations )
just wanted to know if this turbo pulls hard till the 7500 redline and that if the k26 is a better turbo than the 14b
bin files i meant uberdata files... nyone running this setup might wanna help me by givin his file so i can start from there as a base
adios
Old Dec 20, 2004 | 09:50 AM
xenocron's Avatar
Default Re: (soch4u)
http://www.xenocron.com/bins
might be something there for you
Old Dec 20, 2004 | 01:01 PM
b.serious's Avatar
Default Re: (xenocron)
thankssss xenocron
can nyone give me pics of the setup... that wud be great.
ill definately give u guyz update on the install n how it runs..
Old Dec 26, 2004 | 01:13 PM
b.serious's Avatar
well guyz ive got some really bad news.... i just thought of puttin new piston rings and what do i SEE fuckd up rod bearings
took my crank and the rods to the machinin guy and he meaured everythin up and advised me to put new pieces - standard size... they fit perfect
well the turbo project is delayed cuz of budget issues n on top ive got exams for my final term as well ....
l8rzzzzz
adios
Old Dec 26, 2004 | 02:28 PM
93turbo16's Avatar
Pics of the install of a 16g, same thing as a 14b, just a little bigger internally.
http://www.geocities.com/uncgolf25 my car
Old Dec 26, 2004 | 04:32 PM
USDM 4G VTEC's Avatar
my 14B turbo will hold the PSI steady all the way to 7500
if it fluctuates is has been proven to be 0.25psi, and its due to the internal wastegate
Old Dec 26, 2004 | 06:23 PM
Tad's Avatar
Tad
Default Re: (USDM 4G VTEC)
14b's are good.
Just remember this,
they come off dsm's , the OLDER ones,
so your average turbo eclipse or talon you see running around
actually has a t25, those guys run close to 20lbs on easy often.
and guess what, they uset the 14b turbo as an UPRGRADE over the stocker t25.
so yeah, the boost levels any stock block honda is going to run will be no problem for the 14b. And it'll still spool pretty darned quick.
Old Feb 8, 2005 | 11:38 AM
b.serious's Avatar
Default Re: (93turbo16)
thanks guys.. well got over rebuildin my engine cranked da bitch n it sounds great... got the manifold made from a local exhaust shop in town. LOL.. CHEAPPPPPPPPP AS DIRT... 12 buks . LOL..
will be puttin da 14b on tomorrow.. yeyyyyyyyy
one question i have now.. ive seen pictures of the 14b install and the charge pipe and the air filter seems to be on the A/c Compressor side(drivers side). that way the wastegate falls at the back side towards the engine block and is kinda unaccessible.
cant u just install it the other way round to make the air filter and the charge pipe coming out from the passenger side of the car. (i-e where the tranny is) ???
i mean that makes more sense to me.. OPINIONS ... PLZ[/IMG][IMG][/IMG]
Old Feb 10, 2005 | 10:46 PM
Calvinator's Avatar
yah I have no complaints about my 14b
philly10psi
Aug 24, 2011 09:01 AM
icehayden
Jun 21, 2007 10:16 AM
litterbox
Feb 26, 2005 04:38 PM
JdmCIVIC853
Feb 24, 2003 02:12 PM
