anyone use this amp relay?
Old Aug 22, 2006 | 05:53 AM
redboost10's Avatar
Default anyone use this amp relay?
http://store.summitracing.com/...w=sku
just making sure this is alright to use on my fuel pump
Old Aug 22, 2006 | 06:25 AM
turbosi03's Avatar
Default Re: anyone use this amp relay? (tgh99si)
Yeah it will work. Although...
"Prevent voltage drops, maintain fuel pump pressure."
I don't see how a relay can prevent voltage drops when it will be connected to the same voltage supply (your battery) as the original circuit. No caps included in the kit.
Do yourself a favor and solder all connections instead of crimp
Old Aug 22, 2006 | 06:30 AM
redboost10's Avatar
Default Re: anyone use this amp relay? (turbosi03)
ill be sure to solder everything. is anyone running a circuit breaker also? i saw an aeromotive relay harness kit with a 40 amp relay and a 30 amp circuit breaker.
Old Aug 22, 2006 | 08:08 AM
underpressure02's Avatar
That is the same kit I am running in my car with a weldon pump. So far so good.
Old Aug 22, 2006 | 08:47 AM
redboost10's Avatar
awesome, i got a weldone pump too, so thats good to know. thank you
Old Aug 22, 2006 | 09:02 AM
slow poke's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbosi03 &raquo;</TD></TR><TR><TD CLASS="quote">Yeah it will work. Although...
I don't see how a relay can prevent voltage drops when it will be connected to the same voltage supply (your battery) as the original circuit. No caps included in the kit.</TD></TR></TABLE>
Well the stock fuel pump wire is much smaller then the wire included in the kit. So the stock wire will just switch the relay and the power will come directly from the battery VIA the upgraded wire in this kit.
Anyone pushing more then 400HP should upgraded the fuel pump wire even if you are just using a Walbro.
Old Aug 22, 2006 | 09:07 AM
redboost10's Avatar
Default Re: anyone use this amp relay? (slow poke)
this is the way i plan to hook it up, like sfwd 1934
https://honda-tech.com/zerothread?id=1718679
very simple, and no toggle switch, primes with key on.
Old Aug 22, 2006 | 10:40 AM
turbosi03's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow poke &raquo;</TD></TR><TR><TD CLASS="quote">
Anyone pushing more then 400HP should upgraded the fuel pump wire even if you are just using a Walbro. </TD></TR></TABLE>
I see your point.. However, if stock wire is around 20-22ga and this kit has 16-18ga wire... The difference in (I^2)R losses between the two are probably insignificant.
Has anyone ever burned out stock wire from using upgraded fuel pump?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgh99si &raquo;</TD></TR><TR><TD CLASS="quote">ill be sure to solder everything. is anyone running a circuit breaker also? i saw an aeromotive relay harness kit with a 40 amp relay and a 30 amp circuit breaker. </TD></TR></TABLE>
Circuit breaker would work but I would opt for an inline fuse. You definately want one or the other in any circuit you add to your car.
Old Aug 22, 2006 | 11:14 AM
slow poke's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbosi03 &raquo;</TD></TR><TR><TD CLASS="quote">Has anyone ever burned out stock wire from using upgraded fuel pump?</TD></TR></TABLE>
I have not seen any fry but I have seen many cars on the Dyno go lean up top because of the stock wire and walbro. Upgrade the wiring for the pump and the issues disappears. Id say this is a pretty common thing among tuners, ask around.
Its not about resistance loss either, its about how much current the wire supports. The stock wire DOES NOT CUT IT.
Any external pump is going to draw way more current then a stock pump and NEEDS better wire. I go with 14 gauge for my setups though. Dont know about 18 gauge that comes with this kit. 16 should be good though.
nfn15037's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbosi03 &raquo;</TD></TR><TR><TD CLASS="quote">I see your point.. However, if stock wire is around 20-22ga and this kit has 16-18ga wire... The difference in (I^2)R losses between the two are probably insignificant.
How small of a difference qualifies as 'insignificant'?
Old Aug 22, 2006 | 11:20 AM
redboost10's Avatar
Default Re: anyone use this amp relay? (nfn15037)
i plan to run 10 g. wire
Old Aug 22, 2006 | 12:28 PM
slow poke's Avatar
Thats over kill! You will never need more then 12 gauge
Old Aug 22, 2006 | 12:37 PM
redboost10's Avatar
im running it through a distribution block though, check the link i posted above about wiring a kill switch
heres the link on how i will hook it up, its sfwd 1934 way of hooking it up.
Old Aug 22, 2006 | 12:40 PM
turbosi03's Avatar
Ah, I see. The worry is about current limitation rather then pump failure. I agree with Slow Poke with a technical correction:
I was refering to power loss in the wire earlier, but it is exactly about wire resistance. A smaller ga wire electrically looks like a larger resister in a circuit, which is more current limiting due to the power dissipated in the wire. The power loss from the wire must be more significant then I suspected. Probably because the wire runs the lenght of the car...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgh99si &raquo;</TD></TR><TR><TD CLASS="quote">i plan to run 10 g. wire</TD></TR></TABLE>
A walboro pump draws 8amps @ 12volts with 50psi fuel pressure. 10ga wire is good for 20~25amps... Your just adding wieght to your car if that big of wire is used for fuel pump.
Old Aug 22, 2006 | 12:42 PM
redboost10's Avatar
im using a weldon 2035 whcih pulls about 19 amps at 55 psi or somwhere around that psi
Old Aug 22, 2006 | 12:57 PM
turbosi03's Avatar
19 Amps! You would blow a fuse for sure if you tried to run that pump without a relay.
Old Aug 22, 2006 | 01:24 PM
redboost10's Avatar
yeah, thats why i think ill go with a 40 amp one just to be safe, and 10 gauge wire
Old Aug 22, 2006 | 06:59 PM
jz98ctr's Avatar
if you know approximately how much current the pump will be sucking then you will use the appropriately sized fuse for the job. don't overkill the crap out of it cuz if u have a problem where the fuse is supposed to blow u r gonna have evn bigger problems on ur hands. overdrawn circuit+close proximity to fuel=big hole in pocket
jz98ctr's Avatar
and in ur ***
Old Aug 22, 2006 | 09:06 PM
redboost10's Avatar
Default Re: (jz98ctr)
weldon company said to use a 40 amp relay, so i just wanted to know if anyone was using the one that i posted from summit, its the painless brand
jwrape
Jun 7, 2008 12:54 PM
The Tea-father
Jul 12, 2005 11:23 PM
Reelizmpro
Jul 10, 2005 06:33 AM
HatchBox
29
Oct 5, 2004 04:12 PM
B18EG6
Audio / Security / Video
Jul 3, 2003 09:25 PM
