Anyone know what cam this is
Old Sep 15, 2013 | 03:52 PM
ArniFPR's Avatar
Default Anyone know what cam this is
Hi
can anyone tell me what cam this is. it came out of an b16a2
260° intake or something and on the bottom say's UE 1790 9 or UE 1790 G
Old Sep 15, 2013 | 04:11 PM
EsotericImage's Avatar
Retired Moderator
Default Re: Anyone know what cam this is
you can measure them and compare to whats out there
Old Sep 15, 2013 | 10:27 PM
wantboost's Avatar
Who is Mr Robot?
Yea measure the lobes for lift
Here's how you do it:
Get a set of dial or digital calipers
Measure the base circle (where the lobe hasn't started, the circular part) then measure the vtec lobe from the bottom of the cam to the top of the lobe. Subtract the base circle from the lobe measurements and there's your gross lift. You can search on that along with the numbers on the cam and figure out what they are
Also, clearer pictures of the ends of the cam would help a lot. As those are impossible to read
Old Sep 15, 2013 | 10:30 PM
wantboost's Avatar
Who is Mr Robot?
Because I googled all of those numbers and couldn't find ****
Old Sep 16, 2013 | 04:22 AM
Retired Moderator
What brands use an etching gun on their cams?
I know Crane does.
Old Sep 17, 2013 | 11:14 AM
wantboost's Avatar
Who is Mr Robot?
Skunk does, jg did back in the day. So does blox and almost every cam company out there
Old Sep 17, 2013 | 12:17 PM
TheShodan's Avatar
Moderator
Originally Posted by wantboost
Skunk Did, jg did back in the day. So does blox and almost every cam company out there
No. Skunk does not any longer (haven't for about 3 years), GSC does not, and neither does Kelford, Tomei, Toda Racing, or Edlebrock. I'm not sure about SVM, Rocket, or DDTECH.
Old Sep 17, 2013 | 12:56 PM
wantboost's Avatar
Who is Mr Robot?
What about web?
That number could just be a unique identifier to the company that made a custom grind
Old Sep 17, 2013 | 10:04 PM
Ace_Ek's Avatar
i was in the same situation 2 days ago..i got done a lot of research..came out it was a Comp Cam 57300....mine has the same exact etchings. Crane, Zex & Comp Cams uses identical etching process...good luck
Old Sep 28, 2013 | 10:01 AM
DDTECH's Avatar
Not anything of mine.
Old Sep 28, 2013 | 12:14 PM
wantboost's Avatar
Who is Mr Robot?
what about the cams Edelbrock made?
I would simply start emailing every cam company we've listed with the pics and the numbers off the cam until you figure it out
List of companies:
Blox
Rocket Motorsports
Brian Crower
Crower
Edelbrock
Comp
Zex
GSC (doutful it's one of theirs)
Web
Jun
Skunk2
Laskey Racing (they made custom grinds)
that is all I can think of at the moment. like I sad just shoot them and email and include the motor/engine code you're using, pics of the cams (lobes as well and any identifying marks anywhere on the castings) as well as the pics of the etched numbers (try taking a pic with better focus for the numbers) then list the numbers separately (type them out... duh lol)
and hope for a response
I'm sure I'm forgetting some companies
also something I just thought of, they could be OBX cams or any of the typical vtec cams peddled on ebay (I.E. cheap copies)
Old Sep 28, 2013 | 03:34 PM
MRGRIM's Avatar
R.I.P. Mark
why not just take it to a cam grinder and ask to have it dialed for its specs
Old Sep 28, 2013 | 04:32 PM
wantboost's Avatar
Who is Mr Robot?
it already had duration listed
I can measure lobes with a pair of calipers and find cam lift... hell anyone can do it
what you won't know, even if a cam guy measures both cams is center line, LSA, lift at the valve, and so on... you can only get gross lift at the cam, it's not like measuring a sohc cam or a pushrod v8 cam... you need the cam card from the cam maker to truly know what you hae
Old Sep 28, 2013 | 05:07 PM
ArniFPR's Avatar
thanks everyone,
i forgot to post what my search results where, i contacted the guy who owned the car when he put those cams in and he ordered a stage one comp/zex cams and installed them in the car and then sold it,
but after some research i found out he got the wrong cams, these are the comp/zex 59300 so great cams but the motor had stock valvetrain so i guess it's luck that the motor is still ok after 20.000km
Old Oct 21, 2013 | 01:44 AM
ArniFPR's Avatar
after looking over this again, i'm thinking that these are just comp stage 1 cams 57100
but here are some photos, see if you see anything
top of the intake cam,
Top of the exhaust cam, stamped A25 and there is something ethced in there but it's so faded that i can't see it, could be 57103
exhaust cam
intake cam
both cams
Old Oct 21, 2013 | 12:43 PM
wantboost's Avatar
Who is Mr Robot?
you could always try an acid reagent to bring out those faded numbers, basically acid etching, brings that stuff to the surface. similar to how criminalists bring back destroyed serial numbers on firearms
its a decent amount of effort but if it helps you figure out what they are... then I'd say time well spent
Old Oct 21, 2013 | 03:39 PM
DDTECH's Avatar
That intake cam has a 260 degree duration, I can't see the exh but it looks like the exh is stamped too. Those aren't crane or comp, they didn't make anything that big, that MIGHT be a custom spec cam from someone like schinder or something.
Old Oct 21, 2013 | 04:45 PM
bigG's Avatar
check for factory markings might be regrinds
Old Oct 23, 2013 | 03:41 PM
ArniFPR's Avatar
these are the Comp 57100 got confirmed by comp
Old Oct 23, 2013 | 05:22 PM
wantboost's Avatar
Who is Mr Robot?
Glad to hear
Now you need to figure out if this is an appropriate cam choice for your build
luda8890
Feb 7, 2016 03:38 PM
Avi
Mar 27, 2007 04:42 AM
