anyone having problems with rev valve train?
Old Nov 19, 2007 | 03:08 AM
D@nnY's Avatar
Default anyone having problems with rev valve train?
Has anyone seen problems with rev valve train? I ran their stuff and the springs were way to stiff and caused alot of cam lobe and rocker arm wear even with oem R cams. also the valves mushroomed out at the small end. which seems to be a common problem with rev. anyone else seen this?
Old Nov 19, 2007 | 06:20 AM
siblues's Avatar
Default Re: anyone having problems with rev valve train? (D@nnY)
What spring pressure were the springs?I remember reading two posts a long time ago regarding spring pressure .I think they were both from one of the guys at Rocket motorsports.
Old Nov 19, 2007 | 06:29 AM
Turbogixxer's Avatar
No, I ran the same set-up for a customer. Zero problems.
Old Nov 19, 2007 | 06:53 AM
tony1's Avatar
Default Re: (Turbogixxer)
Cam wear from spring pressure is not the valvetrain manufacturers fault. You need a lot of spring pressure for high rpm and the honda rocker arms are too soft. Good oil is the most important thing to stop rocker/cam wear.
The valve problem is a problem.
Old Nov 19, 2007 | 07:19 AM
siblues's Avatar
Default Re: (tony1)
Thanks for the info and what do you think would cause the valves to mushroom?
Old Nov 19, 2007 | 07:34 AM
TDautowerkes's Avatar
Default Re: (siblues)
DID U CHECK TEH SPRING PRESSURE AT THE SEAT HEIGHT WHICH IS LIKE 35-36MM I BELEIVE....
Old Nov 19, 2007 | 10:19 AM
vtekthis's Avatar
Default Re: (TDautowerkes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TDautowerkes &raquo;</TD></TR><TR><TD CLASS="quote">DID U CHECK TEH SPRING PRESSURE AT THE SEAT HEIGHT WHICH IS LIKE 35-36MM I BELEIVE....</TD></TR></TABLE>
arent they linear?
Old Nov 19, 2007 | 01:08 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: (vtekthis)
ran rev stuff last year, switched to maz cams, and had float. thought it was the springs, turns out the dude that did the head, installed the guides too shallow and was binding on the stem seals.
but with the gsr cams, 9800-10k no problems.
Old Nov 19, 2007 | 01:45 PM
BoostedJeff's Avatar
I have heard nothing but good things about Revs stuff.
Old Nov 20, 2007 | 06:42 AM
D@nnY's Avatar
actually seated is 33.5mm and the machine shop said it was over 100 lbs which to me is to high.
what alot of people dont know is rev has 2 different valve springs and the stiffer ones are for cams only up to 11mm lift and your not supposed to run the factory spring locators since they have a stepped inner spring that makes them coil bind .
R cams are 11.5 mm lift so with the stiffer rev springs you cant even run the factory r cams.
Modified by D@nnY at 11:09 AM 11/20/2007
Old Nov 20, 2007 | 06:50 AM
D@nnY's Avatar
Default Re: (D@nnY)
some info
Skunk2 Pro -B series Vtec- 311-05-5350
60lbs seated at 1.320 or 33.5mm
210 lbs @ .820
bind @ .720
Skunk2 tuner springs- B series vtec 311-05-0350
50 lbs @1.320 seated at 33.5mm
210lbs @.820
bind .800
Supertech spr- H1002d
70lbs @ 33.5
190 lbs at 12mm lift
max lift 14mm coilbind -19.5mm
Supertech SPR h100 DR
85 lbs @ 33.5 seated
266 @ 14mm open
15mm max lift 18.5 mm coil bind
xjdmjunkiex
Jul 15, 2012 10:45 AM
ComeOnKip
Mar 11, 2008 09:55 AM
Matty.
Apr 12, 2006 07:40 AM
AnotherGSR
29
Jul 14, 2004 10:30 AM
OBD1EK
Jan 8, 2003 04:55 PM
