Anyone fooled with the hondata autotune functionality?
Old May 20, 2002 | 05:39 PM
dustin's Avatar
Default Anyone fooled with the hondata autotune functionality?
I see it in the software and I assume it works... anyone tried it ?
Old May 20, 2002 | 08:22 PM
Austin's Avatar
Default Re: Anyone fooled with the hondata autotune functionality? (dustin)
Dustin...I know that G3-TEG used it recently and loved the feature...it's something that I look forward to using once I have a stage 4 system and a WBO2....1/2 of the way there.
Austin
Old May 20, 2002 | 08:43 PM
turbocoupe's Avatar
Default Re: Anyone fooled with the hondata autotune functionality? (Austin)
Mine should be here tommorrow. . .I'll check it out.
Old May 20, 2002 | 09:04 PM
PWRVTEC's Avatar
Autotune, I must have missed that where is it? Or is it in some new software they have?
Old May 20, 2002 | 10:17 PM
JT's Avatar
JT
Is this a feature within the RomEditor?
Old May 20, 2002 | 10:38 PM
dustin's Avatar
Default Re: Anyone fooled with the hondata autotune functionality? (JT)
It's in the rom editor.
Old May 20, 2002 | 10:39 PM
PWRVTEC's Avatar
Ok I am dumb I guess....Where?
Old May 21, 2002 | 05:49 AM
00ITR #543's Avatar
Default Re: Anyone fooled with the hondata autotune functionality? (PWRVTEC)
Good question!. I have Romeditor 2.5 and I don't see it anywhere and it's not in the manual...
Dustin plz share...
Old May 21, 2002 | 07:15 AM
dustin's Avatar
Default Re: Anyone fooled with the hondata autotune functionality? (00ITR #543)
There is an autotune percentage under Lambda.
Old May 21, 2002 | 07:28 AM
00ITR #543's Avatar
OK, I have seen that, but I gotta waiting to get my wideband in to try it.
thanks..
Old May 21, 2002 | 08:17 AM
GruvyTune's Avatar
New User
I see it too. I have not seen this thing autotune with wideband sensor.
I don't think it is a functioning feature yet!!
Old May 21, 2002 | 08:19 AM
dustin's Avatar
Default Re: Anyone fooled with the hondata autotune functionality? (GruvyTune)
Ahh, my fears confirmed
You can do it manually with the lambda thing, but that's not fun at all
Doug, you around?
Old May 21, 2002 | 08:21 AM
1337 Si's Avatar
This is on the Hondata correct?
Old May 21, 2002 | 09:22 AM
Hondata's Avatar
The Autotune function is not implemented. There are too many variables like acceleration enrichment, and injector overrun cutoff which change the required air fuel ratio for your given load and rpm value. We have found that rather than tuning on a cell by cell basis it is best to build up a map ( a number of rpm and load points) before making changes to the fuel values. I will post an article on this next week in this forum.
Doug
Old May 21, 2002 | 09:43 AM
Kevin's Avatar
Default Re: Anyone fooled with the hondata autotune functionality? (Hondata)
I cant wait to get the Hondata in our Civic. I wish there was a Toydata for my Camry
Old May 21, 2002 | 09:46 AM
Austin's Avatar
Nice...thank you Doug.
Austin
Old May 21, 2002 | 10:00 AM
blowncivichb's Avatar
Doug freakin' rulez man...
Old May 21, 2002 | 10:24 AM
C-speed's Avatar
Default Re: Anyone fooled with the hondata autotune functionality? (blowncivichb)
There isn't an "autotune" per se... however the Hondata coupled with a wideband O2 and the Datalogging capability of the Hondata system is a powerful tuning tool.
You can set your desired TARGET LAMBDA either in Lambda or A/F values in the TARGET LAMBDA pull down menu. Once that is done, make a power run and log the wideband O2 readings either in the RomEditor or the Hondalogger.
Open up the saved datalog in the RomEditor via the pull down menu. Then scroll forward in time to the portion of the power run in which you are concerned about. (most likely the point where you started the WOT run to redline)
You will see in the PERCENTAGE LAMBDA table how far off your actual A/F readings are as compared to your target Lambda values that you had set before hand. This difference in A/F is on a CELL-BY-CELL basis thus making the tuning and changes extremely easy.
Simply highlight the cell(s) that you wish to modify. For example, at 6500rpms I set my target Lambda at 13.2, however when i made my power run, my actual A/F was 12.5. So you will see a difference number displayed in that cell corrosponding to this difference - 0.7.
Highlight the the cell at 6500 row and corrosponding column and goto the FUEL table. Hit the "U" button seven times and you are done. Continue doing this until all cells have been updated.
Make another power run. You should see that your A/F is now 99% nailed to your target Lambda.
PS: sometimes it is more convenient to highlight a portion of the table that requires changing since changing a single cell affects its' neighboring cells as well because under load the ECU is using a group of 4 cells and averaging their values rather than using the value of a single cell at each load point.
HTH
Lan
Jun 28, 2006 07:16 AM
prwil3030
Jun 8, 2006 06:26 AM
turbotime
Oct 10, 2005 11:56 AM
tencan
Dec 31, 2003 01:36 PM
CovertFI
Jul 10, 2002 02:29 PM
