Anyone else have this problem with their BBK TB?
Old Dec 8, 2006 | 09:30 AM
Kev-turboEJ1's Avatar
Default Anyone else have this problem with their BBK TB?
Sorry if this doesn't below in this section but I figured alot of FI cars use this throttle body.
I have the BBK 70mm Throttlebody mated to a Victor X intake manifold. Sometimes the accelerator pedal inside the car is stiff. I adjusted the cable and the adjustment seems fine. I'm using the stock throttle cable from the d-series on my current B series motor. Sometimes, I'll be cruising in 2nd gear or 3rd gear and when I let off the gas and press again it feels like it opens abruptly and the whole car jerks forward. It's driving me crazyy. Is this some kind of defect that these TB's have? Does anyone else experience the same problem? Thanks for the input.
Old Dec 8, 2006 | 12:27 PM
HiProfile's Avatar
Default Re: Anyone else have this problem with their BBK TB? (TriniRacer)
I know OEM Honda TB's use a sealed bearing on one side, and a bronze bushing on the other; springs on both sides of the shaft. Take the TB off and check both sides, maybe there's no oil on one of the bushings, or a bearing(s) is bad.
You could also just have an old, worn cable - check it out, see if something is binding.
Old Dec 8, 2006 | 12:32 PM
T.J.'s Avatar
I had one of Their TB about 5 years ago, and i use to have the worst time with the Butterfly sticking .
Old Dec 8, 2006 | 12:33 PM
Boostfed's Avatar
New User
From my experience it is pretty normal for aftermarket TBs to stick once in awhile. Some more than others
Psycho719
Apr 17, 2012 09:22 AM
autoluder
Sep 21, 2011 10:49 PM
fatpride111
Dec 5, 2008 05:57 AM
fastprpapi
May 3, 2008 10:09 PM
