Anybody know how to tune the Apexi AVC-D boost controller?
Old Dec 4, 2001 | 07:49 AM
datspeed77's Avatar
Default Anybody know how to tune the Apexi AVC-D boost controller?
What is scramble boost and speed sensitive settings on the AVC-D? Didn't come with instructions on how to use the thing really. I know scramble and speed sensitive is for giving me better traction off the line, but how do you adjust it?
Old Dec 4, 2001 | 09:47 AM
SiCivic99's Avatar
New User
Default Re: Anybody know how to tune the Apexi AVC-D boost controller? (datspeed77)
I just did a long reply up top or I would help you. You can get the manual from apexi's website also in PDF format.
Old Dec 4, 2001 | 09:51 AM
HX_Guy's Avatar
Default Re: Anybody know how to tune the Apexi AVC-D boost controller? (SiCivic99)
Doh!
[Modified by HX_Guy, 10:52 AM 12/4/2001]
Old Dec 4, 2001 | 07:14 PM
datspeed77's Avatar
Default Re: Anybody know how to tune the Apexi AVC-D boost controller? (HX_Guy)
Hey smart guy. It's discontinued, so if you're so smart let me know what's up!
Old Dec 4, 2001 | 09:03 PM
liam821's Avatar
25 Year Member
i have an avcd. The scrable boost is when you connect a button at the back you can increase or decrease boost for x amount of time (by setting the time on the back). The sensitive setting is for drag racing really. By setting that you can have the avcd run more boost at whatever set kph. So it will start boost low and increase the boost (by whatever you have it set) until the reached kph and then stay the same.
I dont use either of these fuctions. I have the speed set at 0 and the scramble set at 0.
Its am awesome boost controller once you get it working how you like it. I can control boost from 5psi -> 18psi with a turn of a dial.
liam
Old Dec 4, 2001 | 10:28 PM
datspeed77's Avatar
Default Re: Anybody know how to tune the Apexi AVC-D boost controller? (liam821)
Thanks for the reply! It makes sense now. If you use the speed sensitive setting wouldn't your traction be much better?
Old Dec 4, 2001 | 11:21 PM
liam821's Avatar
25 Year Member
ya it should help traction...if you get it tuned right. I just went out into the middle of nowhere and did a bunch of burn runs until i got it running how i wanted.
liam
MIdoriEK
Sep 3, 2004 10:03 AM
BoostedsiR
Aug 18, 2003 10:31 AM
turbopanda
May 24, 2002 01:42 PM
sxepride
May 13, 2002 10:37 PM
