any tips for finding a vacuum leak???
Old Jun 23, 2002 | 02:45 PM
morepoop4u's Avatar
Default any tips for finding a vacuum leak???
i'm throwing a cell 14 for the iacv after installing my jrsc. it idles like **** and then eventually stalls. i did the trouble shooting from the helms for the wire connections and the iacv and they where fine. so does anybody have any tips for finding a vaccum leak. i heard you could use propane gas to find it?
Old Jun 23, 2002 | 03:24 PM
Farnsrocket's Avatar
Default Re: any tips for finding a vacuum leak??? (morepoop4u)
mix up some real thick soapy suds (dishwashing liquid) and spread them around the areas you think may have the leak while the car is idling (if your car can still idle)......you will see them get sucked into the area with the leak.
[Modified by Farnsrocket, 4:26 PM 6/23/2002]
Old Jun 23, 2002 | 05:25 PM
tSuperbike69's Avatar
Spray the suspected areas with carb clean if your idle raises then you have found were its leaking from
Old Jun 23, 2002 | 05:57 PM
oscargsr's Avatar
Default Re: any tips for finding a vacuum leak??? (tSuperbike69)
Just do this and you'll find what YOUR looking for
cmsoard
Apr 1, 2009 10:15 AM
DA3
Sep 6, 2008 09:40 PM
racing27
Jul 10, 2007 12:03 PM
Down Shift Motoring
May 14, 2006 11:52 AM
morepoop4u
Jun 23, 2002 08:00 PM
