Any one w/ a compustar and turbo timer?
Old Jun 6, 2002 | 12:57 PM
b00stedsi's Avatar
Default Any one w/ a compustar and turbo timer?
I have a turbo timer I want to put in. I have a 2nd gen compustar alarm. Is this going to work with the remote start. Any info appreciated.
Old Jun 8, 2002 | 12:19 PM
b00stedsi's Avatar
Default Re: Any one w/ a compustar and turbo timer? (turkish)
No one. Crap
Old Jun 23, 2002 | 07:37 PM
silverteg01's Avatar
I'm getting my WSS Compustar alarm this Friday... the starter/alarm combo... how do you like your alarm from them? Is it worth getting? How does the remote start work on a manual?
Old Jun 23, 2002 | 09:16 PM
kidkutz's Avatar
Default Re: Any one w/ a compustar and turbo timer? (silverteg01)
i have that setup...but i can't help you with the install because i didn't do it myself =P
however...i do know that there is a toggle switch for the remote start...
the way it's hooked up is that if it's turbo timed the toggle swtich for the remote starter has to be off. in order to use the remote start...you have to wait for the turbo timing to finish then switch the toggle switch to on. hope this helps
[Modified by kidkutz, 1:16 AM 6/24/2002]
Old Jun 28, 2002 | 07:25 AM
b00stedsi's Avatar
Default Re: Any one w/ a compustar and turbo timer? (kidkutz)
Thanks, thats the solution...
I like my 2nd gen compustar very much. the pageing remote gives a sence of security. The remote start works by setting the parking brake. When you pull up on the e brake it tells the compustar that your in neutral. you get out of the car and it will still run untill you shut the door. Now its set for the remote start. Now if open your door to get something the remote start will not work for reasons that you could have put it in gear or who ever went in there.
inh
Audio / Security / Video
Jul 23, 2008 12:52 PM
type B16
Jan 8, 2007 04:49 PM
WildChild
Dec 6, 2005 12:57 PM
teg969
Mar 29, 2004 12:49 PM
GroundZer0 336
16
Aug 19, 2003 04:43 AM
