Any one using this manifold?
Old Jan 1, 2010 | 10:41 AM
Robert Padron's Avatar
Default Any one using this manifold?
Hi everyone. I want to know if anyone is running this manifold? I know some hold up and others don't, but I realy want to run a ramhorn.
Also, I have been running a t3 off a 84' 300zx at 10psi, and I'm going to install a .50 trim t3/t4. I'd like to know how many psi on the t3/t4 would equal the 10psi on the t3.
Old Jan 1, 2010 | 05:17 PM
TehGhett0P1mp's Avatar
Default Re: Any one using this manifold?
Go ahead and run it I am sure it will make power!
Old Jan 1, 2010 | 05:30 PM
RC000E's Avatar
I have to question the wall thickness and materials used. Cyl. 2 and 3 are not weld el's. I'm wondering if its cut to appear to look like a sch. built mani or not. JUNK....china pride ching chong right there. Don't be surprised when it cracks.
Old Jan 1, 2010 | 05:46 PM
king06's Avatar
Looks cheap
Old Jan 1, 2010 | 06:47 PM
K7-1Ktrevor's Avatar
Loved
Community Favorite
oooo shiny.
Old Jan 1, 2010 | 07:23 PM
chippinpressure's Avatar
stay away from that S!@#
Old Jan 1, 2010 | 11:56 PM
CO_RaceFab's Avatar
garbage i would rather use a cast manifold
Old Jan 2, 2010 | 04:24 AM
DaBeastALLBOOST's Avatar
its going to crack for sure
Old Jan 2, 2010 | 08:22 AM
I apreciate the comments. But don't you guys think this one would be made a little better then the normal ones, since it's made for a 50mm wastegate. Instead of the ones that are made for a 35, 38mm wastegate?
Old Jan 2, 2010 | 08:32 AM
reaction360's Avatar
nope. and who mani just like this n who even makes a square flanged 50mm gate? i've seen a mani just like this n they had clearance issues between the turbo n gate.
Old Jan 2, 2010 | 08:42 AM
Well, as far as clearance between the wastegate and the turbo. I'm gonna cut off the wastegate pipe on the ramhorn and have a 90 degree bend welded on along with a 38mm wastegate flange so it can be a/c compatible.
Old Jan 2, 2010 | 09:12 AM
TIGboy's Avatar
dont buy this. there are so many better options. The material is garbage, the welds are garbage..its not worth it.
Old Jan 2, 2010 | 09:20 AM
Evo1's Avatar
OG Fabricator
lol it's not that easy FYI
I guessing by your responses that you already purchased this manifold?
I say sell it, buy a nice tubular or if you can't afford it get it a cast manifold
Old Jan 2, 2010 | 02:15 PM
yeah i'm not sure what your intentions were for this post. You wanted peoples opinion and everyone has told you its junk, yet you still try n defend it or make compromises. To me, your decision was made before you even made this post. And i'm sorry but you're not going to get any support from people on here to help you feel good about running this manifold.
The manifold will work don't get me wrong. Just don't expect it to last and be prepared to constantly take it off the motor for repairs.
Old Jan 2, 2010 | 11:15 PM
crvek9's Avatar
yes dont use that...they r junk...go cast!!
Old Jan 2, 2010 | 11:56 PM
_kiid's Avatar
bling bling
its gonna crack!
Old Jan 3, 2010 | 04:07 AM
nihad's Avatar
Originally Posted by _kiid
bling bling
its gonna crack!
You gotta start some where buy it..
Old Jan 3, 2010 | 04:21 AM
pi Ka chuuu's Avatar
dont use that kind of manifold. i posted something similar to this when some one asked about the ram horn manifold. but these are very poorly made and are of low quality, they will crack eventually. dont go boost if u arent going to buy quality parts
RSX2SIcivic
Jun 25, 2009 02:12 PM
HamiltonRex
Dec 24, 2008 07:39 PM
h22turbolude
Dec 10, 2003 09:30 AM
