Any one have this greddy turbo timer problem
Old Mar 27, 2005 | 01:51 PM
6shootahorsenamedtrigga's Avatar
Default Any one have this greddy turbo timer problem
Sorry for this long story. Okay I have a ej1. I installed the greddy full auto turbo. All wiring is correct; the timer works fine but has this problem: When I use the blinker it makes it shut off and then it immediately comes back in. Its like a loose connection but only when the blinker comes on. Only one time it shut off when I put it in reverse (reverse light). Thing is, it does not do it all the time with the blinker just about 80% of the time. I rechecked all the wiring and its not a loose connection. I also tested the voltage drops while hitting the blinker from the timer harness, different ground points, and at the battery...they are pretty much the same. Here are the voltage drops while they key is on (motor is not)
ground and red wire 12.2 drops to 12.10
ground and green wire 12.2 drops to 11.8
ground and battery 12.2 drops to 12.2
red wire and neg battery 12.2 drops to 12.2
I cant understand why it would cause it shut off..maybe recheck connections again? Or maybe just a slight voltage drop causes this timer to mess up because its defective? Someone give me some insight
Old Mar 27, 2005 | 02:34 PM
shadow103rd's Avatar
Default Re: Any one have this greddy turbo timer problem (mphinesee)
Im willing to bet its defective...or you need to find a better ground....
But since you check the voltage drops on multiple locations, Im putting my money on it being defective....Thew Greddy TT's are junk IMO. Apexi TT
JOn
Modified by shadow103rd at 3:45 PM 3/27/2005
Old Mar 27, 2005 | 03:26 PM
Default Re: Any one have this greddy turbo timer problem (shadow103rd)
Thanks...well does neone encounter this problem?
Old Mar 27, 2005 | 08:40 PM
PrettyLude's Avatar
lemme guess, its the second version of the tt from greddy right?
Old Mar 28, 2005 | 08:18 AM
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">lemme guess, its the second version of the tt from greddy right?</TD></TR></TABLE>
yes it is..r u having similar issues too?
Old Mar 28, 2005 | 08:43 AM
PrettyLude's Avatar
its trash man, get a hks one, do a seach for the greddy tt, u will read that it works when it wants to, not all the time
importracer3
Dec 5, 2005 07:30 PM
crxvtecturbo
Oct 25, 2005 01:10 PM
Stu22
Apr 13, 2005 11:02 AM
heygotboost
Apr 12, 2005 07:44 PM
JMinSi2000
May 15, 2002 03:36 PM
