Re: any new 6262 dyno numbers?
I did this a long time ago 6262's were still new check out video
http://www.youtube.com/watch?v=HrlpjXxMD94 |
Originally Posted by TheShodan
(Post 45567911)
Trying to give those Neon lights from StreetGlow on a comeback run, eh? j/k. ;-)
Originally Posted by BrockB
(Post 45576227)
I'm one of the few that still loves them and I'll say it proudly- as long as theyre installed correctly and the car is still fast, I have no shame lol
Originally Posted by RATEDX1
(Post 45565528)
810hp @ 28lbs e85
6262 .82ar vband jdl topmount turbo kit dual backdoor intercooler dual bosch 044 pumps AEBS closed deck block 9.1 pistons manley rods with carr bolts built head pro1 cams 00 civic si |
Originally Posted by _k20a2_
(Post 45583258)
That seems pretty high for 28psi on a 6262, even if it is churches high reading dyno. Do you have a sheet? I'm not calling bs, but what trap speeds have you run?
(Post 45583258)
^ uhhh o
that 810hp is on a Dynapack, FYI.
(Post 45576227)
Really, if I thought my EF had a chance to look decent with some lights I would probably rock them. |
Originally Posted by SLIM NOTHING
(Post 45583535)
na its pretty close to the end of the power on the turbo. he just has a good setup. pretty close to what im finishing now. im just wondering how the clearances on the pro1s are...
Just got off the dyno last week. 533whp at 20psi on e85 but not done waiting for my hasport motor mounts to come and should be going on this week or next week and thorwing in some c16 to max out my stage 5 clutch. Turbo is a pte 6265 t4 with a 1.15 AR
Originally Posted by Evo1
(Post 45584237)
His is a special 6262...The kind where you don't pay someone for it and rip them off:thumbdown:
(Post 45583258)
and the best time on the car so far is 10.80 @ 135 no vtec...first time out.. |
(Post 45599703)
i tried calling either you or your partener a few times with no answer...last i heard you guys were moving and never heard from u guys...i still got the same # 7026968706...call me if you wanna make things rite! and yes that turbo is bad ass..i guess it was worth the wait for 3 months..after you told me itll take a week.
will post up dyno sheet later... and the best time on the car so far is 10.80 @ 135 no vtec...first time out.. http://i4.photobucket.com/albums/y14...2/66341729.jpg |
Originally Posted by chrisdiz
(Post 45599862)
Here a pic of the sheet..
(Post 45613766)
just lookad at the other sheet...and the 810 was on 33lbs...
(Post 45613766)
Evo guys make over 800 on the turbo as well (dynojet) with crazy torque and have gone 8s on the 6262
http://www.youtube.com/watch?v=xuT3P5Sb2us |
Finished mine a few months back.
D16z6 Eagle rods/wiseco pistons Comp 59300 GE sleeved & o-ringed block 75.5mm AFI forward facing Pte t3 6262 .82 a/r housing Tial 44mm Made 618hp @32psi. Only 13* at peak ve. Cracked the front of the block, so we had to stop. I fixed it, now tuning will be finished at the track. But has been trapping 139-140 @ 30 psi is 3rd and 4th (boost by gear) time to get aggressive :P |
u broke the front of your block too? or did i already know about that? lol
i made 654whp and 542wtq on a local mustang dyno with my evo. 6262 jb. .82 a/r 32psi e85
Im doing a top mount and putting the v band .82 housing on and plan to make more power i did 584hp at 28 psi on a ram horn and .63ar. Im also going to a victor x from a skunk 2 so im hoping to make 650.
not trying to thread jack, but im stuck between the 2 turbos as well and dont want to start a new thread beating an old topic.
i have a 84x89mm sleeved manley tt rods manley 9.5:1 pistons endyn b16 fully ported head type r cams aeromotive a1000 victor x t4 ramhorn manifold i want around 500 on 93/meth and 700 or just under on race gas I am stuck between 6262 because in t4, 6262's biggest housing is .68 and it has me concerned as far as egt's go would you think that 6265 would be a lot laggier on my setup, and which a/r exhaust housing would you run on the 6265 in for input thanks! |
here is what i just did to my 6262 thanks to member TurboFocus for ordering my parts and redoing my turbo setup
http://i170.photobucket.com/albums/u...ewtopmount.jpg http://i170.photobucket.com/albums/u...btopmount2.jpg will have new dyno numbers when its all done. It will be cool to see how much I pick up from the .82 compared to the .63. But im also changing from a ramhorn to a top mount and changing intake manifolds. |
