any new 6262 dyno numbers?
Old 03-15-2011, 07:55 PM
b00stedOne's Avatar
Default any new 6262 dyno numbers?
i was just wondering if anyone has any recent dyno numbers running with a 6262 or 6265? seen alot of builds but no numbers.
Old 03-15-2011, 09:49 PM
AllShowNoGo727's Avatar
Default Re: any new 6262 dyno numbers?
ls vtec 84mm 6262 ball bearing 63. ar ported s cover number in sig.
DelSolMarine's Avatar
there are so many on the web its crazy...
s2ki.com has a lot on there as well....
the 6262 and 6265 are definitely putting down power!
Old 03-16-2011, 05:20 AM
CDecker0218's Avatar
I just got a 6265 billet and should be on the dyno by the end of next month and hopefully update everyone on how these turbos really are!
Old 03-16-2011, 06:44 AM
ExVtec's Avatar
6262 bb w/.82 a/r made 650whp on my 05 2.2l s2k
Old 03-16-2011, 08:47 AM
d16z6Tcrx's Avatar
im guesing i put out around 430 giving my mph but my buddy put down 800 spinning the wheels on the dyno @ 30psi and up on his .82 6262 t3 on a 2.0 and ctr cams.
Old 03-16-2011, 09:02 AM
OG Fabricator
Evo1's Avatar
Had a friend just put down 540 ish @ 17-18psi. Stock sleeve ls/vtec.
Old 03-16-2011, 08:03 PM
B00st3d-dc2's Avatar
what's the setup?
I'm looking for 500 - 550 stock sleeve hopefully by mid next month.
b18c, t4 6262 ported S cover, skunk2 tuner 2 cams, victor x
Old 03-16-2011, 08:18 PM
B20luda's Avatar
i will be pushing my 6265 on my H22 hear pretty soon, hope to break 700whp
Old 03-16-2011, 09:47 PM
BLaCKWiDoWSi's Avatar
Going on the dyno on Monday. Just on pump gas though. 84mm Gsr sk2 tuner cams. 6262. Waiting for the Bosch 044s and fpr to come in for the race gas. will post up results next week
Old 03-16-2011, 09:52 PM
94GSRMR's Avatar
371whp 252.8ftlbs 17lbs
Ls/vtec wiseco 9.0:1, eagle rods, go-autoworks ramhorn manifold,
Precision 38mm wastegate, 1000cc injectors
I could have easily done 400 but my duty cycle was at 84% which is prob a vacuum leak but i prob was down 10whp but the turbo is pretty nice on spool.
Old 03-16-2011, 09:53 PM
94GSRMR's Avatar
Type r cams
Old 03-17-2011, 05:09 AM
ExVtec's Avatar
Thats a little high given the boost pressure. On the motors I've seen it takes it into the 30's a bit just to hit 700whp.
Old 03-17-2011, 07:32 AM
.CUBISH.'s Avatar
62/62 journal 750hp 30 psi
62/65 bb 825hp 30 psi
2.0 Gsr
Old 03-17-2011, 08:05 AM
spectacle's Avatar
On my 2.0L S2k
Old 03-17-2011, 08:50 AM
boosted2.4's Avatar
A guys evo that i know made 800hp on a 6262
might have to read though it to find it
http://forums.evolutionm.net/evo-dyn...16hp-2-4l.html
Old 03-17-2011, 11:25 AM
heetstroke's Avatar
6262 Journal Bearing
611/390 on 25lbs
https://honda-tech.com/forums/forced-induction-16/got-car-tuned-6262-sleeved-gsr-e85-2908493/
Old 03-17-2011, 06:05 PM
16 psi
Old 03-20-2011, 01:05 PM
MadVTI's Avatar
Some big numbers there guys, off to dyno on thurs here in UK with a Sleeved B16 with journal 6262 .82 turbo. Hoping to crack 600hp at crank on 30ish PSI. Keep u posted.
Old 03-20-2011, 02:11 PM
b00stedOne's Avatar
yeah man keep us updated for sure. Videos are always nice too
Old 03-20-2011, 02:58 PM
MadVTI's Avatar
will do, ill get both of course.
Old 03-20-2011, 03:49 PM
94GSRMR's Avatar
Bump for more Numbers and set-ups... P.S Im revving to 8100rpm, i could up it to 8400...
Old 03-20-2011, 04:01 PM
ashb82's Avatar
what rpm are you able to hit boost
Old 03-20-2011, 04:21 PM
94GSRMR's Avatar
94GSRMR's Avatar
sorry for blurry pics
Quick Reply: any new 6262 dyno numbers?
