any new 6262 dyno numbers?
i was just wondering if anyone has any recent dyno numbers running with a 6262 or 6265? seen alot of builds but no numbers.
Re: any new 6262 dyno numbers?
ls vtec 84mm 6262 ball bearing 63. ar ported s cover number in sig.
there are so many on the web its crazy...
s2ki.com has a lot on there as well.... the 6262 and 6265 are definitely putting down power! |
I just got a 6265 billet and should be on the dyno by the end of next month and hopefully update everyone on how these turbos really are!
6262 bb w/.82 a/r made 650whp on my 05 2.2l s2k
im guesing i put out around 430 giving my mph but my buddy put down 800 spinning the wheels on the dyno @ 30psi and up on his .82 6262 t3 on a 2.0 and ctr cams.
Had a friend just put down 540 ish @ 17-18psi. Stock sleeve ls/vtec.
Originally Posted by Evo1
(Post 44876387)
I'm looking for 500 - 550 stock sleeve hopefully by mid next month. b18c, t4 6262 ported S cover, skunk2 tuner 2 cams, victor x |
i will be pushing my 6265 on my H22 hear pretty soon, hope to break 700whp
Going on the dyno on Monday. Just on pump gas though. 84mm Gsr sk2 tuner cams. 6262. Waiting for the Bosch 044s and fpr to come in for the race gas. will post up results next week
371whp 252.8ftlbs 17lbs
Ls/vtec wiseco 9.0:1, eagle rods, go-autoworks ramhorn manifold, Precision 38mm wastegate, 1000cc injectors I could have easily done 400 but my duty cycle was at 84% which is prob a vacuum leak but i prob was down 10whp but the turbo is pretty nice on spool. |
Type r cams
Originally Posted by d16z6Tcrx
(Post 44876278)
62/62 journal 750hp 30 psi
62/65 bb 825hp 30 psi 2.0 Gsr |
A guys evo that i know made 800hp on a 6262
might have to read though it to find it http://forums.evolutionm.net/evo-dyn...16hp-2-4l.html |
6262 Journal Bearing
611/390 on 25lbs https://honda-tech.com/forums/forced-induction-16/got-car-tuned-6262-sleeved-gsr-e85-2908493/ |
Some big numbers there guys, off to dyno on thurs here in UK with a Sleeved B16 with journal 6262 .82 turbo. Hoping to crack 600hp at crank on 30ish PSI. Keep u posted.
Originally Posted by MadVTI
(Post 44901799)
will do, ill get both of course. :)
Bump for more Numbers and set-ups... P.S Im revving to 8100rpm, i could up it to 8400...
what rpm are you able to hit boost
sorry for blurry pics
