any need for oil restrictor?
Old Nov 12, 2001 | 04:34 PM
GruvyTune's Avatar
New User
Default any need for oil restrictor?
Is there a need to have an oil flow restrictor into the turbo if the tap is off the oil pressure sending unit??
Old Nov 12, 2001 | 09:41 PM
VaporTrail's Avatar
New User
Default Re: any need for oil restrictor? (GruvyTune)
top. I'd like to know myself
Old Nov 13, 2001 | 05:25 AM
rtype11's Avatar
I dont use a restictor and have had no oiling problems, I have a big shaft turbo and use -3 and my return is -12, you can call Turbonetics and they will tell you about oiling requirements for your particular setup, maybe all you need is to tap the head for some light. I am trying to work out a way to run a Y block out of my oil cooler to the turbo, that would be trick!
GT500FTW
Feb 13, 2013 10:40 AM
RACEPAK
May 25, 2004 09:07 AM
71 mgb
Nov 12, 2003 10:49 AM
