Any info on the GT32?
Old Jun 17, 2005 | 02:07 PM
adeihl's Avatar
Default Any info on the GT32?
Hey guys... searched and oly founf 10 articles... but didnt find the info i needed.
Does anyone have any info/experences with the GT32 non wastegate type?
COMPRESSOR: EXHAUST:
71mm 52 .50 64mm 73 .78
Trying for about 325 WHP on a 2.0 hyundai engine. 8.5:1 compression 6750 redline. I have looked at the comrpessor map and it seems to be 'ok' to me? I am just worried about the larger exhaust housing and turbine for a slow spool ... although it is twin scroll. Any input/advice would be great! thanks guys,
Andrew
Modified by adeihl at 11:30 PM 6/17/2005
Old Jun 17, 2005 | 03:04 PM
m R g S r's Avatar
Default Re: Any info on the GT32? (adeihl)
1.6L b16a....about 11.0 to 1 compression
GSR head
rest of setup is in my sig
at 7.5psi i made about 270whp....
Old Jun 17, 2005 | 10:00 PM
adeihl's Avatar
how was the spool up time? laggy as shat?
Old Jun 17, 2005 | 10:05 PM
s2kdre's Avatar
Default Re: (adeihl)
isnt that turbo on backorder?
Old Jun 17, 2005 | 10:41 PM
adeihl's Avatar
from garrett direct i think so... some supplyers have a new left though.
Old Jun 18, 2005 | 08:18 AM
m R g S r's Avatar
laggy? not really....
4100 rpm i see full boost....well almost....after vtec kicks i see another .5psi or so...but thats probally just spiking up a bit.....
i am running 3" opendownpipe thou....and equal length header
on a log mani, it should spool a little faster.
i kno b18flip was running a gt32e on his gsr and said he saw full boost by 3900 with an inline pro manifold
Old Jun 18, 2005 | 08:51 AM
TheShodan's Avatar
Moderator
Default Re: (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">laggy? not really....
i kno b18flip was running a gt32e on his gsr and said he saw full boost by 3900 with an inline pro manifold </TD></TR></TABLE>
You gotta remember that these turbos come in 3 different compressor diameter sizes that affect its initial spool characteristics, as well as the fact that your compression is much higher than the average bear, so that will also affect its on boost response.
Old Jun 18, 2005 | 11:46 AM
shortyz's Avatar
with a 6750 redline, i would go with something alot smaller... for a street car smaller is always "funner"
Old Jun 18, 2005 | 01:00 PM
Chip's Avatar
Default Re: (TheShodan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote">the fact that your compression is much higher than the average bear, so that will also affect its on boost response.</TD></TR></TABLE>
Gee, how many times did I hear that before I bought into a high compression turbo setup.
Old Jun 18, 2005 | 01:12 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (Chip)
if the exhaust housing is twin scroll and listed in the exhaust ar's you are most likely looking at a t4 version of the gt32, which will be incredibly laggy
Old Jun 18, 2005 | 02:10 PM
adeihl's Avatar
hmm 4100 RPM for 7.5 PSI of boost seems incrediably laggy. thanks everyone for your posts... any other opinions are appreciated!
Andrew
amalby
May 10, 2008 04:44 AM
v8hnta
Dec 14, 2007 07:35 AM
spooler
Aug 20, 2003 05:30 PM
