Any H22 Nitrous??
Old Feb 18, 2009 | 06:09 AM
H2BSTUPID's Avatar
Default Any H22 Nitrous??
Hi, i'm thinking of doing a small shot (50-75) this summer at the track only, just curious to see if others here have a H22 nitrous set-up
i would like to know the set-up and results!
Thanks
Old Feb 18, 2009 | 06:19 AM
Garcia-Racing's Avatar
Default Re: Any H22 Nitrous??
Stock h22 in a gutted hatch and 80 shot direct port 11.46 yeeeears ago
Old Feb 18, 2009 | 09:29 AM
wolve's Avatar
50-75 shot can be done on a stock d15
h22 won't probably even notice it's being sprayed
Old Feb 18, 2009 | 10:43 AM
H2BSTUPID's Avatar
lol!! if thats what you think!
i'm pretty sure you would notice quite a difference!
Old Feb 18, 2009 | 11:01 AM
FST GSR 1's Avatar
He meant you could put a lot more into it if you wanted if you do it right, 50-75 on that H2B is like comparing penny's to dollars IMO.
Old Feb 19, 2009 | 03:30 AM
H2BSTUPID's Avatar
Ahh ok, yeah i know!!
i'm kinda new to this nitrous stuff!!
i'm not looking to gain 2 secs or anything on the 1/4 mile just a lil boost to help out a bit!!!
here is my set up -
p&p head
p&p intake manifold with iab's removed
skunk2 pro 2 cams & gears
Full skunk2 pro series valve train
skunk2 high compression valves
type s pistons
eagle rods
shaved head
b16 lsd tranny
now the track we have here sucks ***** but i want to run a low 12 or high 11 second pass, i'm probably in the 220-250 whp range and don't think i'll hit the times i want alone so a 50-75 shot should get me there!
Old Feb 20, 2009 | 01:14 PM
91tealhatch's Avatar
i ran a 12.9 on a 40 shot with a ebay header, untuned.
this year im going for a 75 shot i have a new header (rmf knockoff) and a chipped p28 looking for low 12's i hope
if anybody is wondering why its slow for a H series i believe its cause im in MT at 4k above sea level.
Old Feb 25, 2009 | 11:20 AM
worx's Avatar
here is my set up -
p&p head
type s pistons
eagle rods
shaved head
b16 lsd tranny
we have the same set up except for the tranny. we wanna run nitrous but we were looking at shooting like 150shot
Old Feb 25, 2009 | 11:41 AM
spoolin turbo s's Avatar
id just make sure its tuned by a good tuner
how strong are those type s pistons? how much power have they been proven to handle reliably?
the safest and best way in my opinion would be to run direct port with a progressive controller and run as much as those pistons can handle because from looking at your mod list the pistons look to be the weak link
the progressive controller is kinda expensive but definately worth it ill put it like i told the d series guy that was asking nitrous q's
i would definately invest in a progressive nitrous controller FOR SURE because it could easily make your motor last plenty longer due to not hitting it all at once but progressively increasing the amount of nitrous. For instance your drag racing, you could set it up to progressively increase the nitrous to the point that you barely have traction but still have traction, next gear same thing, so on and so on and by the time you get to the last gear your going to be in. You may be able to handle a 200-250 shot and still keep traction and increasing speed and lowering your ET.
Get what im saying here about the progressive controller?
running nitrous like this is awesome for straight line racing from what i've seen on domestics
WARNING
this is to the best of my knowledge on the nitrous part, so if im wrong hopefully someone with more knowledge will correct me
Old Feb 25, 2009 | 11:44 AM
FST GSR 1's Avatar
Spoolin, have you ever tuned, built or owned a nitrous car?
Old Feb 25, 2009 | 11:50 AM
No
i've just been around a lot of them mostly domestics
im just learning on these motors and nitrous i sent you a pm
educate me what am saying that is wrong because on a domestic what i said is the safest way to run alot of nitrous safely i know some doing what i said in my above post running low 9's high 8's
progressively adding in more nitrous and fuel until you get to the end of the 1/4 mile.
Old Feb 26, 2009 | 09:28 AM
lexan2.2sedan's Avatar
Thread testimate numero tres: Please sticky the nitrous thread.
Repeitive posts and un-true information shouldn't be what the forum strives for.
Old Feb 26, 2009 | 09:39 AM
boostedcivicsir's Avatar
Mr. Badwrench
https://honda-tech.com/forums/forced-induction-16/%2A%2A%2A-official-nitrous-thread%2A%2A%2A-2119397/
detailzdelivere
Sep 17, 2009 03:18 PM
projectef
May 27, 2007 11:52 AM
Mammad
Feb 5, 2003 09:17 AM
