Any drawbacks to saturated 440's
Old Jan 2, 2003 | 03:40 PM
BoostedGSRBubble's Avatar
Default Any drawbacks to saturated 440's
i understand the difference between saturated and peak n hold (thanks search). But the only drawback I can find is the size limitation. I want saturated b/c of ease of install. Are they less safe or less reliable or less consistant than p&h. Ill be running 6.5 lbs, also. Thanks.
Old Jan 2, 2003 | 04:03 PM
sutrusu's Avatar
Default Re: Any drawbacks to saturated 440's (trustsi)
your car runs saturated injectors from the factory. it'll be fine.
Old Jan 2, 2003 | 05:25 PM
Default Re: Any drawbacks to saturated 440's (sutrusu)
I know, i just didnt want my injectors to be a weak link.
Old Jan 2, 2003 | 05:36 PM
Sonny's Avatar
They'll be fine. The only drawback is that if you wanna go larger than 440, you have to run peak-and-hold (low impedance) injectors.
If you're not gonna max out the 440's though, they will work fine. As mentioned above, your car comes with saturated injectors.
Sonny
Old Jan 2, 2003 | 05:56 PM
MikePalm's Avatar
Default Re: Any drawbacks to saturated 440's (Sonny)
Actually, you can get saturated 550cc RX7 injectors. I didn't know this until recently.
88-? RX7 Turbo II part # 195510-1680
DJaeMac
Sep 28, 2007 03:06 PM
doodooheadfart
Feb 22, 2007 09:53 PM
b20b
Feb 5, 2002 09:14 PM
