any difference between 4 bolt and 5 bolt turbine
Old Oct 15, 2005 | 03:21 AM
tdo's Avatar
tdo
Default any difference between 4 bolt and 5 bolt turbine
is the 5 bolt better then the 4 bolt turbines?
im doing some research for a turbo setup im going to piece together and someone told me that the 5 bolt one is better but didnt give me a reason why.
tried searching with no luck, and i know this is a odd question but anyone got any info on this?
Old Oct 15, 2005 | 05:23 AM
a1320addict's Avatar
Default Re: any difference between 4 bolt and 5 bolt turbine (tdo)
bump..i would like to know some technical reasons as well
Old Oct 15, 2005 | 05:37 AM
DaveF's Avatar
Default Re: any difference between 4 bolt and 5 bolt turbine (yehiknowrite)
from what i understand......
the 4 bolt is "better" than the 5 bolt, because there is no "wastegate hole" to cause any disruptions in the exhaust gas flow.
Old Oct 15, 2005 | 05:52 AM
TheShodan's Avatar
Moderator
Default Re: any difference between 4 bolt and 5 bolt turbine (Dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">from what i understand......
the 4 bolt is "better" than the 5 bolt, because there is no "wastegate hole" to cause any disruptions in the exhaust gas flow.</TD></TR></TABLE>
It doesn't matter for the wastegate hole because if you're using a weld flange for the 5 bolt, it will completely seal that hole regardless.
The only advantage of the 5 bolt turbine exhaust housing is its placement of the turbo from a particular manifold (Rev-Hard is a perfect example) for downpipe placement. From my experience, its the removal of the 5th bolt is the PITA that makes it a determining factor. So for example, Inline Pro makes their SS manifolds specifically for both 4 bolt exhaust housings and 5 bolts separately. this is for downpipe placement as well as positioning for the turbo on the manifold.
I have always used 4 bolt housings because of the ease of removal, and the less amount of material for the manifold to deal with.
Old Oct 15, 2005 | 06:52 AM
DaveF's Avatar
Default Re: any difference between 4 bolt and 5 bolt turbine (TheShodan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote">
.</TD></TR></TABLE>
but the "hole" will be there and still disrupt flow, the 4 bolt is a smoother housing.
Old Oct 15, 2005 | 07:04 AM
igo4bmx's Avatar
i always thought the 4 bolt was better flowing compared to a 5bolt
Old Oct 15, 2005 | 07:18 AM
TheShodan's Avatar
Moderator
but the "hole" will be there and still disrupt flow, the 4 bolt is a smoother housing.</TD></TR></TABLE>
Its quite negligeble thermodynamically speaking, really...
Old Oct 15, 2005 | 07:26 AM
DaveF's Avatar
Its quite negligeble thermodynamically speaking, really...</TD></TR></TABLE>
understandable....
i just like arguing on H-t j/k
Old Oct 15, 2005 | 08:13 AM
BlackT5's Avatar
I was wondering this too.. especially after reading this on ATPturbo
" The GT30R turbine housings with 4 bolt exit are made out of ductile Ni-Resist iron (has a nickel content of about 38%). This material is much better at withstanding high exhaust gas temperatures than regular cast iron. "
Old Oct 15, 2005 | 08:59 AM
TheShodan's Avatar
Moderator
Default Re: (BlackT5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackT5 &raquo;</TD></TR><TR><TD CLASS="quote">I was wondering this too.. especially after reading this on ATPturbo
" The GT30R turbine housings with 4 bolt exit are made out of ductile Ni-Resist iron (has a nickel content of about 38%). This material is much better at withstanding high exhaust gas temperatures than regular cast iron. "</TD></TR></TABLE>
But that is just the metalurgy of the housing itself, not on the 4 bolt design. Ni-Resistant Iron and Carbon steel are both good materials to use other than Cast iron, but is not always available on the specific turbos.
Old Oct 15, 2005 | 09:30 AM
PeakBoost's Avatar
B*A*N*N*E*D
Default Re: (TheShodan)
simply put,
5bolt = on center
4bolt = tangential
the 4bolt housing actually allows the exhaust gas to meet the inducer of the turbine much sooner than the 5bolt.
the 5bolt entry is almost on top of the shaft...
and yes, for arguements sake, the wastegate port on the volute of the 5bolt can cause a bit of turbulance.
hth
edit: as mac said though, due to some manifold placements, the 5bolt is the only option. this is the only reason we still offer a 5bolt option.
Old Oct 16, 2005 | 10:33 AM
BlackT5's Avatar
Default Re: (PhoenixTurbo.com)
There's a little more info in this thread
https://honda-tech.com/zerothread?id=144234
b20vtech
Dec 3, 2007 09:22 AM
tyflip2
Jan 29, 2004 05:04 PM
RudeLude
Jan 3, 2004 12:49 AM
88 rex
Jul 24, 2003 02:18 PM
