Any chance i'm drilling through this Inline Pro?
Old May 3, 2004 | 07:15 PM
Hoosier Daddy's Avatar
Default Any chance i'm drilling through this Inline Pro?
Gonna tap it for EGT. Any chance i'm gonna drill through this, or will I have to bring it to a shop? I have the cast 4 bolt.
Where would be the best place to drill it? I know this has been discussed a million times
Old May 3, 2004 | 07:25 PM
99B16Si's Avatar
id do it in the collector or the #3 runner. and no it wont be that hard to drill thru at all as long as u have a dent drill and bit
Old May 3, 2004 | 09:09 PM
Default Re: (99B16Si)
Nice. I drilled through my HKS manifold, but the IP seems so thick.
Old May 3, 2004 | 09:50 PM
MaxSterling's Avatar
Default Re: (Hoosier Daddy)
cast iron is ez to drill thru, soft metal
Old May 3, 2004 | 09:58 PM
Default Re: (MaxSterling)
Sweet
Old May 3, 2004 | 10:13 PM
Phaze2 Mike's Avatar
cyl 1 owns you
Old May 3, 2004 | 10:15 PM
V-SPEC 1's Avatar
Default Re: Any chance i'm drilling through this Inline Pro? (Hoosier Daddy)
here you go, check this out.
https://honda-tech.com/zerothread?id=852282
Old May 3, 2004 | 10:32 PM
Default Re: Any chance i'm drilling through this Inline Pro? (boostedb20vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedb20vtec &raquo;</TD></TR><TR><TD CLASS="quote">here you go, check this out.
https://honda-tech.com/zerothread?id=852282</TD></TR></TABLE>
Sweet ****. That's exactly where I was thinking about drilling it.
Old May 3, 2004 | 10:54 PM
Br1t1shguy's Avatar
so youre doing this with the manifold of right?
Old May 4, 2004 | 10:25 AM
Default Re: Any chance i'm drilling through this Inline Pro? (Br1t1shguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Br1t1shguy &raquo;</TD></TR><TR><TD CLASS="quote">so youre doing this with the manifold of right?</TD></TR></TABLE>
Of course
Old May 4, 2004 | 11:18 AM
TRUST8383's Avatar
what kind of drill bit are you guys using? I already did mine, but it took FOREVER!! haha Seriously, i must have been sitting there for a lifetime, and I also went thru 2 T-handles tapping that biotch. Wish i had a drill press
Old May 4, 2004 | 12:08 PM
Its just the same doing it with it on if done right, might be easier with it on because it be secure.
Old May 4, 2004 | 01:14 PM
Default Re: (Phaze2 Mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phaze2 Mike &raquo;</TD></TR><TR><TD CLASS="quote">Its just the same doing it with it on if done right, might be easier with it on because it be secure. </TD></TR></TABLE>
Well, you don't want any metal shillings going through the turbo.
dfoxengr
Welding / Fabrication
11
Nov 22, 2007 05:42 PM
Antilag
Jan 5, 2006 09:58 AM
David S. Wallens
13
Aug 1, 2005 09:43 AM
tony n.
Mar 9, 2005 05:28 PM
Chillinit
Mar 10, 2004 04:40 PM
