Any 350+ whp SOHC's?
Old Dec 30, 2003 | 09:53 AM
KrautFed's Avatar
Default Any 350+ whp SOHC's?
I was wanting to take a look at some of the setups the higher HP SOHC guys are running. I am building a SOHC car (VW) and IIRC, the flow numbers between VW & Honda SOHC's were similar. Just like the Honda market, most VWers choose DOHC or the VR6 (6 cyl) as their platform, which has pretty much left the SOHC out to dry.
I've been hanging around the site for a few months, and finally registered and did a lot of researching, but not much info on higher HP SOHC cars.
Thanks for any help.
Old Dec 30, 2003 | 10:00 AM
TurbodCX's Avatar
Default Re: Any 350+ whp SOHC's? (KrautFed)
Look at sig, this was with last years setup. Looking for 450+ as soon as my Tial gate shows up.
Brian
Old Dec 30, 2003 | 10:03 AM
KrautFed's Avatar
Default Re: Any 350+ whp SOHC's? (TurbodCX)
Thanks! You say fully built... do you have any head work? What size turbo was that...and what turbo will you be using 450?
Old Dec 30, 2003 | 10:06 AM
TurbodCX's Avatar
Yes the head is fully built with full ferrea valve train.
I was using a .60/.63 Ar garret T3/T04E, and will be using the same turbo again for 450,but i will be pushing to its limits, and 30psi.
Brian
Old Dec 30, 2003 | 10:18 AM
KrautFed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurbodCX &raquo;</TD></TR><TR><TD CLASS="quote">I was using a .60/.63 Ar garret T3/T04E, and will be using the same turbo again for 450,but i will be pushing to its limits, and 30psi.</TD></TR></TABLE>
Wow! How was spool up with that hot side? Good luck with that turbo.
Would you happen to have any head flow numbers?
I'm what you would call, ignorant , what's the displacement of your motor?
Old Dec 30, 2003 | 10:23 AM
TurbodCX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KrautFed &raquo;</TD></TR><TR><TD CLASS="quote">
I'm what you would call, ignorant , what's the displacement of your motor?</TD></TR></TABLE>
I see full boost of 20psi by like 4500-5000. I rev the engine to 8k.
I do not have any head flow #'s at all.
But i do beleive this turbo will be plenty big for my HP goals.
The motor is a 75mm bore and still a 1.6L
Old Dec 30, 2003 | 10:59 AM
KrautFed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurbodCX &raquo;</TD></TR><TR><TD CLASS="quote">The motor is a 75mm bore and still a 1.6L</TD></TR></TABLE>
The motor I have lined up right now is 82.5mm bore with 92.8mm stroke (2.0L)
My flow #'s are at the house, but I believe they are in the neighborhood of ~170cfm intake and ~140cfm exhaust IIRC.
..after reading some of your older posts, I have a lot of reading to do.
Old Dec 30, 2003 | 11:17 AM
TurbodCX's Avatar
Awesome. good luck bro! and a big for sticking with the SOHC!!
Brian
Old Dec 30, 2003 | 11:36 AM
M.A.R.C.'s Avatar
told u brian... we're taking over
good luck to both you guys!
Old Dec 30, 2003 | 12:01 PM
ladysman's Avatar
Default Re: Any 350+ whp SOHC's? (CivicRyda2k)
Ninja powah!!!
Old Dec 30, 2003 | 02:16 PM
ZEX Man's Avatar
Short Block:
D16Z6 block
Darton solid-deck ductile iron sleeves
ARP head studs
Crower steel-billet rods
JE custom 9-1 pistons
Cylinder Head:
D16Z6 SOHC V-TEC cyl. head (unported)
D16Z6 intake manifold (port matched)
Stock throttle body
ZEX™ valve springs (912-16)
ZEX™ camshaft (59300)
Performance distributor with MSD wires
Induction Set-up:
60-1 Hi-Fi Turbonetics turbo, TO4 exh. with stage 5 wheel (23 PSI boost)
910 cc injectors
2 stage nitrous system, 245 hp (120 hp direct port, 125 single nozzle dry)
Exhaust:
Turbonetics ported cast turbo manifold w/ custom TO4 flange
This set-up should be making upwards of 500whp……haven’t dynoed, but the et is all that matters
Later,
ZEX Man
Old Dec 30, 2003 | 02:34 PM
runwhatubrung's Avatar
Default Re: Any 350+ whp SOHC's? (ZEX Man)
some nice numbers showing here
Old Dec 30, 2003 | 03:52 PM
SCD16A6's Avatar
anyone know what the stock d series sleeves are good for??400hp maybe??
Old Dec 30, 2003 | 05:31 PM
5thgencivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZEX Man &raquo;</TD></TR><TR><TD CLASS="quote">Short Block:
D16Z6 block
ARP head studs
Cylinder Head:
Stock throttle body
Induction Set-up:
910 cc injectors
Exhaust:
This set-up should be making upwards of 500whpÂ…Â…havenÂ’t dynoed, but the et is all that matters
Later,
ZEX Man
You are my idol! lol
Old Dec 30, 2003 | 05:59 PM
Justin Olson's Avatar
Default Re: Any 350+ whp SOHC's? (5thgencivic)
Honda SOHC's are still 16v right?
Justin
Old Dec 30, 2003 | 06:12 PM
Disco Stu's Avatar
Default Re: Any 350+ whp SOHC's? (olsonjus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by olsonjus &raquo;</TD></TR><TR><TD CLASS="quote">Honda SOHC's are still 16v right?
Justin</TD></TR></TABLE>
Yes.
As for all you d series guys with the big turbos, what are you revving to? I'd like to run a larger sized turbo that won't run out of steam in the higher rpms. My t25 falls flat on its face at 5500 and I don't shift until 6500-7250rpm when racing. I'd like a bigger turbo to be able and have a stronger upper-rpm powerband. And for the bigger turbo guys, when is boost kicking in. Thanks.
Old Dec 30, 2003 | 06:49 PM
civic2nr9177's Avatar
bump for the questions about how much horsepower will the d series sleeves hold and for the guys with the big turbos, when is boost kickin in.
SOHC rules. Cant wait til i rake in some money and build the crap out of my d16z6.
Old Dec 30, 2003 | 09:09 PM
.dave's Avatar
i HAS questions ?
Default Re: (Kikomon)
It depends on how well tuned the car is. I'll know by spring as I'm running stock sleeves looking to make 350+ on my D16Y8.
Old Dec 30, 2003 | 11:08 PM
norcalcrx's Avatar
Default Re: (dtmamg)
Mine is holding 250whp just fine on stock sleeves. Looking for 300whp soon.
Old Dec 30, 2003 | 11:11 PM
integlspwr2k's Avatar
Default Re: (norcalcrx)
just wondering whats the point of spending all that time and money in to a SOHC when it could be done to a DOHC motor?
Old Dec 30, 2003 | 11:15 PM
norcalcrx's Avatar
Default Re: (integlspwr2k)
Much cheaper to build what you have, then buying a swap and having to build it. D series motors make the tq like the ls.
Old Dec 30, 2003 | 11:51 PM
Disco Stu's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integlspwr2k &raquo;</TD></TR><TR><TD CLASS="quote">just wondering whats the point of spending all that time and money in to a SOHC when it could be done to a DOHC motor?</TD></TR></TABLE>
For me, it comes down to usable horsepower on the street. Anything over 250/250 to the wheels in any fwd honda without new suspension, tires and clutch, on the street is *insert own opinion here* running the risk of serious traction issues unless you're on the highway. Yes, many will disagree on that, but i'm talking about the majority of cars who don't have traction bars and a gear based boost controller with a two step launch control, and drag radials on the car 24/7. I'd just prefer to save the money that I'd need to spend to buy a b series engine, new mounts, (in my case) wiring harness and put it into a nice turbo setup and engine management on my d16. Even on a d16 with a nice engine management setup and a good turbo setup, it's very possible to reach the upper limits of "usable" power on the street as it is. Now if you factor in the price of just a decent turbo setup even without decent engine management for the b series, you could have bought yourself new pistons and rods for the d series.
I still dream of owning a big, built turbo b18c1 in my crx someday, but until I have the ability to own a second car as a daily driver, that's not gonna happen. And that's the case with a bunch of guys on here. If i had a dedicated daily driver, and a ton of money, then yes, I'd build a b series, 5th gear burnout machine.
Cliffnotes: The D-Series engines, in my mind, have all the potential in the world of reaching the upper limits of "usable" horsepower on the street. Not to mention it can do it on a turbo that reaches full boost at 3000 rpm and can hold strong until redline.
Old Dec 30, 2003 | 11:55 PM
racinskittle's Avatar
Simple. I want 250whp. I can do this with my stock engine and prolly $4000 worth of mods. To me it's worth it.
Right now I've spent a total of $2000 on my kit and would say im close to 200whp. To me, that's some cheap HP. With another $2000 invested. Im hoping to make 250+ whp SAFELY.
Old Dec 31, 2003 | 12:01 AM
Disco Stu's Avatar
Default Re: (racinskittle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racinskittle &raquo;</TD></TR><TR><TD CLASS="quote">
Right now I've spent a total of $2000 on my kit and would say im close to 200whp. To me, that's some cheap HP. With another $2000 invested. Im hoping to make 250+ whp SAFELY.</TD></TR></TABLE>
Damn, that's basically what I was trying to say, without being so damn long-winded. The d series affords you the opportunity to obtain cheap, usable (meaning quick spool and strong until redline) horsepower and torque.
Old Dec 31, 2003 | 12:29 AM
nigel's Avatar
I have a b16 in my hatch with the turbo kit in the closet(wating for a fuel pump and blowoff valve) but if I were to do it all over again I would have gotten a d series. for sheezey.
