Another B20 bites the dust...
Old Nov 29, 2006 | 05:44 PM
david@didrace.com's Avatar
Default Another B20 bites the dust...
Our shop manager took the car out to the track over the weekend while I was away for Thanksgiving. Only got to make one pass - 12.0 @ 23mph. Puff of smoke after being in 5th gear for a split second. Clutch in, motor off.
Did a compression test first - 63psi, 0psi, 0psi, 170psi. Cylinder #4 was a champ! Stock B20 w/ 20psi ~ 385whp on our Mustang dyno with the clutch slipping above 6500 rpm.
Cylinders 1, 2 & 3 are all cracked. Pistons #2 & 3 are melted right where the sleeve cracked.
Old Nov 29, 2006 | 05:48 PM
American.Graffiti's Avatar
Default Re: Another B20 bites the dust... (david@didrace.com)
DAMN!!! So the real question is whats the plans for the new setup?
Old Nov 29, 2006 | 05:50 PM
Jared's Avatar
damn, detonation owns you
Old Nov 29, 2006 | 05:52 PM
non-VTEC's Avatar
good tuning job on that
Old Nov 29, 2006 | 05:57 PM
Default Re: (Jared)
I only tuned it for 10 psi. Kinda wanted the motor to blow so we upped the boost w/o additional tuning. We had it on the dyno, wideband read ~ 13.5:1 (.90 Lamda) but I didn't change anything because I was going to be swapping it out over the winter. It still took 3 months of beating on it for it to break.
Old Nov 29, 2006 | 06:28 PM
Jared's Avatar
I love 13.5:1 with boost.
Old Nov 29, 2006 | 07:01 PM
93turbo16's Avatar
Props for blowing up a otherwise good block and having less usable parts because it was fun to blow up and be ignorant.
Old Nov 29, 2006 | 07:03 PM
triple_s1x's Avatar
Default Re: (Jared)
Wow that looks pretty bad, almost as bad as when i split david's gfs 0-ring in a fisting accident.....
RIP: b20..
Old Nov 29, 2006 | 07:58 PM
triple_s1x's Avatar
Default Re: (triple_s1x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 &raquo;</TD></TR><TR><TD CLASS="quote">Props for blowing up a otherwise good block and having less usable parts because it was fun to blow up and be ignorant.</TD></TR></TABLE>
HaHa, yea were a bunch of ignorant *****, after we blow up motors for fun. We punch pregnant women in the gut for a good laugh.
Who really cares it was a 2dollar motor, worth nothing to begin with. Made a good amount of power, and lasted 5x times longer then we expected or wanted. I was planning on tossing a built motor in the car right after the WMHM, but for everybody that was there the car ran awesome, and continued running awesome on that tune with 10-15 more pounds of boost. I also highly doubt it was anywhere near 13.5:1, but none the less who cares i really wish it would of tossed a rod or something. To each there own.
Old Nov 29, 2006 | 08:39 PM
nonvtecD's Avatar
Default Re: (93turbo16)
Ha, people blowing up motors for fun, especially DOHCs is funny to me too. It lasted longer than you wanted it to? So when you were driving it you were like "Man I hate that this 385 hp motor is running so well and is so fast I really wish it would blow up" ? I'm not hating, but that motor definitely was worth more than 2 dollars I totally would have given you 3 for it.
Old Nov 29, 2006 | 08:55 PM
93turbo16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by triple_s1x &raquo;</TD></TR><TR><TD CLASS="quote">
Who really cares it was a 2dollar motor, worth nothing to begin with. Made a good amount of power, and lasted 5x times longer then we expected or wanted. I was planning on tossing a built motor in the car right after the WMHM, but for everybody that was there the car ran awesome, and continued running awesome on that tune with 10-15 more pounds of boost. I also highly doubt it was anywhere near 13.5:1, but none the less who cares i really wish it would of tossed a rod or something. To each there own. </TD></TR></TABLE>
Don't really care, it is the disregard that I don't like.
It is just an act of ignorance. But whatever, it just doesn't make much sense to me. Next time, send it to me, I will pay for shipping
Old Nov 29, 2006 | 09:07 PM
SovXietday's Avatar
Lol, you effectively combined cylinders two and three.
I wish I had the money to blow up motors for ***** and giggles, AAA must hate you guys.
Old Nov 29, 2006 | 09:10 PM
SOHC_MShue's Avatar
Yea for real...if you see it running 13.5:1 on the dyno then why not simply add a little more fuel in?
Old Nov 29, 2006 | 09:54 PM
BfromSD's Avatar
Default Re: (SOHC_MShue)
it would sux if a peace of metal went into the turbo and blew that up to....
Old Nov 29, 2006 | 09:55 PM
dunkd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">Yea for real...if you see it running 13.5:1 on the dyno then why not simply add a little more fuel in?</TD></TR></TABLE>
prolly had stock injectors @ 189% duty cycle lol
Old Nov 29, 2006 | 10:06 PM
Suprdave's Avatar
I've never seen one melt between the cylinders like that...hah cool.
Old Nov 29, 2006 | 11:01 PM
HiProfile's Avatar
Default Re: (Suprdave)
In a way threads like this make me mad. I have a car with a hole in its block, one which might have a bearing issue - and here you intentionally blow **** up.
Stock limits of 385whp for a b20 vs 250ish for a d16... kinda makes me wonder why I'm stuck with D's. Then I look at my tuition bill
You think it was more from thin sleeves flexing due to heat & cyl pressure? Since it was mainly by the sleeve 'bridges', I'd expect it started where the oil was getting by the rings in those areas.
Old Nov 30, 2006 | 03:18 AM
non-VTEC's Avatar
Default Re: (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote"> You think it was more from thin sleeves flexing due to heat & cyl pressure? Since it was mainly by the sleeve 'bridges', I'd expect it started where the oil was getting by the rings in those areas.</TD></TR></TABLE>
i'd say to much timing and to little fuel judging by how everything is melted.
Old Nov 30, 2006 | 03:38 AM
jameelrose's Avatar
wow, nice home made mutiple displacement system you created there. lol
Old Nov 30, 2006 | 06:23 AM
TorganFM.'s Avatar
Default Re: (jameelrose)
What kind of temperature does it take to melt sleeves?
Old Nov 30, 2006 | 06:36 AM
triple_s1x's Avatar
Default Re: (Mr.S8N)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.S8N &raquo;</TD></TR><TR><TD CLASS="quote">What kind of temperature does it take to melt sleeves?</TD></TR></TABLE>
No idea, but if you give me a couple weeks.. I'll try this experiment again, and give you exact test data... B20s are like 2 for $500 at password i think, I'll just hold off and only buy one hooker this weekend and save some money.
Old Nov 30, 2006 | 06:49 AM
Ha, some of these replies made me laugh.
Old Nov 30, 2006 | 06:55 AM
triple_s1x's Avatar
Default Re: (david@didrace.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by david@didrace.com &raquo;</TD></TR><TR><TD CLASS="quote">Ha, some of these replies made me laugh. </TD></TR></TABLE>
Being ignorant is not funny you bastard, I hope you burn in hell. You could of sold that motor, and fed the entire country of Somalia for 6 days.
Old Nov 30, 2006 | 07:05 AM
93turbo16's Avatar
Being ignorant is not funny you bastard, I hope you burn in hell. You could of sold that motor, and fed the entire country of Somalia for 6 days. </TD></TR></TABLE>
I hope next time it bites you in the ***.
Old Nov 30, 2006 | 07:08 AM
I hope next time it bites you in the ***. </TD></TR></TABLE>
Hater-Tech.Com
