another "is this oil return ok thread"....
Old Apr 18, 2005 | 03:27 PM
acurar0ss's Avatar
Default another "is this oil return ok thread"....
The hose ovals out a little on the bend... any ideas on how I can smooth the bend out a little or does this look ok?
93turbo16's Avatar
maybe 45 off the turbo and angle the pan up a bit more, and shorten the hose.
Old Apr 18, 2005 | 03:30 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (93turbo16)
angle the fitting at the pan up more and get a 45 off of the turbo
Old Apr 18, 2005 | 03:32 PM
acurar0ss's Avatar
Default Re: another "is this oil return ok thread".... (acurar0ss)
so a 45 on both the pan and the turbo.. I will give it a try.... I will see if I can angle it up some more.
Old Apr 18, 2005 | 03:42 PM
oxSLEEPERxo's Avatar
from the pic, theres a big kink, do what 93turbo said
Old Apr 19, 2005 | 05:16 PM
acurar0ss's Avatar
Default Re: another "is this oil return ok thread".... (oxSLEEPERxo)
ok... I followed the above advise... thanks.. it looks alot better now.
Should I shorten the hose more and angle the fitting at the pan up more or just leave it?
Old Apr 19, 2005 | 05:22 PM
s2kdre's Avatar
alot better you could use a 90 from the pan
Old Apr 19, 2005 | 05:50 PM
DragSource's Avatar
It's fine man - you're set.
Old Apr 19, 2005 | 05:54 PM
acurar0ss's Avatar
Default Re: another "is this oil return ok thread".... (jdmhonda)
would'nt a 90 put another bend in the hose.... or bow it out?
Old Apr 19, 2005 | 05:57 PM
dustin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acurar0ss &raquo;</TD></TR><TR><TD CLASS="quote">
leave it like this. looks great.
Old Apr 19, 2005 | 06:36 PM
Default Re: another "is this oil return ok thread".... (dustin)
looks good
Old Apr 20, 2005 | 03:56 AM
acurar0ss's Avatar
thanks for all the help
Old Apr 20, 2005 | 04:11 AM
White Smoke's Avatar
i my honda
Global Mod
All good now
Old Apr 20, 2005 | 04:15 AM
Davep's Avatar
You could get one of these to eliminate the NPT to AN fitting.
Ebay
Old Apr 20, 2005 | 05:22 AM
acurar0ss's Avatar
Default Re: another "is this oil return ok thread".... (Davep)
Ya I saw that after I already bought my current fitting... oh well.
Old Apr 20, 2005 | 06:23 AM
slowsi00's Avatar
good ****
a good return line is always good to know in the back of your mind u wont have to worry about it.
mine was always sketchy and i always thought about it.
Old Apr 20, 2005 | 07:42 AM
BauleyCivic's Avatar
Risky Business
Default Re: (slowsi00)
As long as the oil is always flowing down, and not pinched, your fine. In your first picture it looked like the return line dipped down and then back up, but it looks good now.
Better than my first attempt:
Old Apr 20, 2005 | 10:55 AM
acurar0ss's Avatar
Default Re: (BauleyCivic)
did you run it like that and if so did it flow oil?
Old Apr 20, 2005 | 11:11 AM
vangc6780's Avatar
Default Re: (acurar0ss)
whats wrong if its pinched just a little like that last picture???
Old Apr 20, 2005 | 11:15 AM
dornon13's Avatar
Default Re: (vangc6780)
it could potentially cause oil to backup into the turbo and out the seals causing your turbo to leak and smoke therefore needing a rebuild
Old Apr 20, 2005 | 11:33 AM
civicross's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">As long as the oil is always flowing down, and not pinched, your fine. In your first picture it looked like the return line dipped down and then back up, but it looks good now.
That one would benefit from a 90 on the pan.
And a good set of AN wrenches
Old Apr 20, 2005 | 12:13 PM
acurar0ss's Avatar
thats what I hate about those fittings... if you dont tape them and use the right wrench they get scratched way to easy....
Old Apr 20, 2005 | 02:32 PM
civicross's Avatar
Never tape an AN fitting.
Old Apr 20, 2005 | 02:35 PM
dustin's Avatar
Default Re: (civicross)
I think he means tape the outside so the finish doesn't get scratched...
Old Apr 20, 2005 | 02:42 PM
civicross's Avatar
Default Re: (dustin)
Ah. That works too.
Teflon Tape+An Fittings=Bad
The vise jaws that have cut outs for fittings are really nice if you build alot of hoses.
