AMS shop evo new setup.
Old May 30, 2006 | 03:27 PM
4-ageTOg63's Avatar
Default AMS shop evo new setup.
UPDATE: New dyno vid of this beast 988awhp on top of page 4.
I searched, didn't find anything.
Just wondering how effecient this setup is compared to traditional...I'd imagine it would be very effecient...and have their been any honda setups like this?
Modified by 4-ageTOg63 at 2:47 PM 6/5/2006
Old May 30, 2006 | 03:29 PM
redzcstandardhatch's Avatar
something different
holy crap thats wild. i love it
Old May 30, 2006 | 03:31 PM
B18C1CYA's Avatar
Default Re: AMS shop evo new setup. (4-ageTOg63)
****** sweet
Old May 30, 2006 | 03:33 PM
4-ageTOg63's Avatar
Default Re: AMS shop evo new setup. (B18C1CYA)
I just wish there was a good picture of the exhaust side of the turbo.
Old May 30, 2006 | 03:35 PM
dr_latino999's Avatar
How does the oil return work there?
Old May 30, 2006 | 03:38 PM
4-ageTOg63's Avatar
Default Re: AMS shop evo new setup. (dr_latino999)
If you look in the 4th picture just above the middle of the I/C i believe the oil return goes to a pump.
Old May 30, 2006 | 03:45 PM
AbitAvenger's Avatar
the intercooler is too small
sike that **** is sick
Old May 30, 2006 | 03:47 PM
beak's Avatar
That manifold is gonna go crackity crack crack...
And what the hell is the point of mounting it there?
Old May 30, 2006 | 03:49 PM
alpha's Avatar
Looks "similar" to an exhaust manifold Tony1 fabricated a while back. Looks great. I'm sure they branced the Hell out of the turbo
Old May 30, 2006 | 03:51 PM
4-ageTOg63's Avatar
Default Re: (beak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beak &raquo;</TD></TR><TR><TD CLASS="quote">That manifold is gonna go crackity crack crack...
Don't be ******* stupid.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0x64 &raquo;</TD></TR><TR><TD CLASS="quote">Looks "similar" to an exhaust manifold Tony1 fabricated a while back. Looks great. I'm sure they branced the Hell out of the turbo</TD></TR></TABLE>
As stated, i've been trying to find any honda setups like this...the efficiency on a bigger motor with the turbo mounted right off the I/C would be awesome I would presume.
Old May 30, 2006 | 04:06 PM
fknfast's Avatar
Default Re: (4-ageTOg63)
isnt that a shearer fab manifold?? or did they copy it just like all their other manifolds??
Old May 30, 2006 | 04:11 PM
beak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4-ageTOg63 &raquo;</TD></TR><TR><TD CLASS="quote">Don't be ******* stupid.</TD></TR></TABLE>
If I was ******* stupid, I'd be ******* you.
As stated, i've been trying to find any honda setups like this...the efficiency on a bigger motor with the turbo mounted right off the I/C would be awesome I would presume.</TD></TR></TABLE>
You would presume incorrectly. The gains from blowing the turbo right into the intercooler, or through two feet of pipe before the intercooler is not something I would wet my panties about. Don't be ******* stupid.
Old May 30, 2006 | 04:17 PM
alpha's Avatar
I said "similar". Not exactly.
Old May 30, 2006 | 04:18 PM
B18C1CYA's Avatar
Default Re: (beak)
And what the hell is the point of mounting it there? </TD></TR></TABLE>
I dont think it will crack , turbo is supported properly and the motor looks to have solid mounts also , so no movement
Old May 30, 2006 | 04:19 PM
beak's Avatar
Default Re: (B18C1CYA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA &raquo;</TD></TR><TR><TD CLASS="quote">I dont think it will crack , turbo is supported properly and the motor looks to have solid mounts also , so no movement </TD></TR></TABLE>
The turbo is supported, but that car is probably making 1000hp, and it doesn't look like the supports have much play....
Old May 30, 2006 | 04:30 PM
crazy_eddy's Avatar
but, How do they make the oil return line work (on the Evo for example) Oil supplay should be a problem but how du you suck the oil from the turbo back to the Oil pan ??
Old May 30, 2006 | 04:33 PM
igotyofire's Avatar
Default Re: (beak)
if u ask me it seems pretty obvious that the turbo is gonna get better airflow around it, keeping it cooler as well as cooler air to compress, therefore making it more effiecient and now the intercooler wll has less hot air to cool, or be able to produce cooler air temps. and also getting rid of unecessary pipes which help add to pressure drop which reduces the boost..so now the car may be able to run more timming and boost without detonating so quickly tho its not neccessary but i also do belive theyre are trying to extract every pony possible out of these evos. tho also in theory one could argue it is simpley heat which drives the turbine and now placing the turbo fruther is only going to help produce more lag...so as to this i am unsure
Old May 30, 2006 | 04:35 PM
Bailhatch's Avatar
Default Re: (crazy_eddy)
scavange pump for the oil return. lots of cars use them
for crazy eddy^
Old May 30, 2006 | 05:11 PM
crazy_eddy's Avatar
@ Bailhatch
Thanks a lot for the info. Do you have a link where i can buy something like that?
Would be great if.
Thanks again
Old May 30, 2006 | 05:14 PM
raceACCORDingly's Avatar
a ramhorn w/ compressor going into a backdoor IC.
Old May 30, 2006 | 05:54 PM
racinskittle's Avatar
Default Re: (fknfast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fknfast &raquo;</TD></TR><TR><TD CLASS="quote">isnt that a shearer fab manifold?? or did they copy it just like all their other manifolds??</TD></TR></TABLE>
Comon...It's AMS.....they're ALWAYS first at coming second. lol
Old May 30, 2006 | 05:56 PM
*Boostwerks*'s Avatar
Damn I love AMS. I love to see creativity spawn new ideas.
Old May 30, 2006 | 06:12 PM
JDM_EM1's Avatar
Default Re: (beak)
looks sick
Old May 30, 2006 | 06:18 PM
HKSuperSi's Avatar
thats crazy looking .
Old May 30, 2006 | 06:24 PM
mrbsponge's Avatar
i like the little tabs that are welded to the intercooler pipe and the intercooler with the bracket to keep a pipe from accidentally popping off!
