Aluminum for exhaust?
Old Jul 30, 2003 | 10:02 AM
Bnjmn's Avatar
Default Aluminum for exhaust?
I was reading on the Burns site that they don't recommend aluminum for exhaust piping. Why would they say this? I was thinking of using aluminum after the catalytic converter- is this a bad idea?
Thanks
Ben
Old Jul 30, 2003 | 10:57 AM
GraphiteAccord's Avatar
Default Re: Aluminum for exhaust? (Bnjmn)
it'll melt.
Old Jul 30, 2003 | 11:10 AM
Overblown-Teg's Avatar
Default Re: Aluminum for exhaust? (GraphiteAccord)
I wondered that also. maybe just for the muffler.. My muffler does not get very hot.. I would say less hot than my intake manifold..
Old Jul 30, 2003 | 11:55 AM
Tinker219's Avatar
Default Re: Aluminum for exhaust? (Overblown-Teg)
the ultimate combination for exhaust materials on a turbo charged car would be a
Heat-wrapped turbo manifold and turbo paired with an un wrapped aluminum exhaust. This will utilize pressure differences between hot and cold, and will allow quicker spool, more hp, etc.
BUT, the tricky part is keeping the aluminum by the turbo in one piece. Someone try it..if nobody does in the next month, I will on my new setup...
Old Jul 30, 2003 | 01:01 PM
rioninja's Avatar
Default Re: Aluminum for exhaust? (Tinker219)
nice... thats good thinking. heat differences would almost suck the exhaust out, in a matter of speaking.
Old Jul 30, 2003 | 01:11 PM
Bnjmn's Avatar
Come on...I think you guys are full of baloney. A cat. converter's operating temp is around 600 degrees. 6061 Aluminum has a solidus temp of 1080 degrees F. Anyone ever put an EGT probe around the end of the downpipe? I'd be really surprised to see anything that would melt aluminum.
Old Jul 30, 2003 | 01:15 PM
meanteg's Avatar
New User
Yeah, why no one does that ? I wanna know too.
Bnjmn's Avatar
Regarding the temp differences and having the Al section "suck" out the hotter exhaust- is this really going to happen? The Al exhaust piping wouldn't run any cooler than a comparable piece of steel- if anything it would run hotter since Al is a much better conductor of heat than steel?
Old Jul 30, 2003 | 01:50 PM
xci_ed6's Avatar
That is the point. it will conduct the heat from the exhaust to the atmosphere through the tube walls.
-Dustin
Old Jul 31, 2003 | 02:59 AM
Tinker219's Avatar
Default Re: Aluminum for exhaust? (krustindumm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krustindumm &raquo;</TD></TR><TR><TD CLASS="quote">That is the point. it will conduct the heat from the exhaust to the atmosphere through the tube walls.
-Dustin</TD></TR></TABLE>
Yep. Im not sure how great of a difference it would make, but just basic physics laws pretty much proves that it will make a difference.
Old Jul 31, 2003 | 05:48 PM
Full-Race Javier's Avatar
yes, in theory it would work. u have to also consider that exhaust gasses and by products of combustion (like water) can shorten the downpipes life by corroding the material. AL will conduct more heat than mild steel and ss.....but it wont be able to withstand the harsh conditions like stainless can. u have to make comprimises
AL 6000 series:
-thermal conductivity=<u>166.9 W/m-K</u> or <u>1160 BTU-in/hr-ft²-°F</u>
Mild steel 1000 series:
-thermal conductivity=<u>51.9 W/m-K</u> or <u>360 BTU-in/hr-ft²-°F </u>
Stainless 304L:
-thermal conductivity=<u>16.3 W/m-K</u> or <u>113 BTU-in/hr-ft²-°F </u>
Old Jul 31, 2003 | 07:03 PM
stierhund's Avatar
Default Re: Aluminum for exhaust? (javierb14)
aluminum can withstand the conditions just as well as steel if your talking about exhaust gases but not the temp changes... wether or not it will melt between 1080 and 1220 F is not the point... its the fact that it goes through temp changes daily and the structure bends quicker, but I bet that thick aluminum would hold up if it were welded well, and thats not easy to do
Old Jul 31, 2003 | 08:13 PM
tony1's Avatar
Default Re: Aluminum for exhaust? (stierhund)
I've seen it done after the first bend on a drag car. The first bend takes most of the heat and you can do aluminum from there. This is on a drag car though, i don't think it'll last too long on a street car...
Old Jun 2, 2004 | 03:32 AM
Tinker219's Avatar
Default Re: Aluminum for exhaust? (tony1)
I think Im going to try this on my SRT4. 15k miles since Dec. 1st of 03, I drive a lot!
Back from the dead
Old Jun 2, 2004 | 04:56 AM
xci_ed6's Avatar
I forgot I even posted in this, let us know how it works!
Old Jun 2, 2004 | 05:30 AM
tony1's Avatar
I did it on Rado's car, we'll see how it holds up. If nothing else, it's super light!!
Old Jun 2, 2004 | 05:48 AM
Tinker219's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote"> If nothing else, it's super light!!</TD></TR></TABLE>
Thats my thought on the PIG peon...
just have to flange for mufflers is the only drawback.
Old Jun 2, 2004 | 05:55 AM
dasher's Avatar
Ti exhaust is light also , but like aluminum doesn't hold up very well ... I guess its a great Idea it you don't mind changing your exhaust every couple years...
... I also was about to fork out the cash for an Aluminum or Ti exhaust for weight issues ... then realized that the exhaust weight sits so low to the ground that it wouldn't help handling that much ... Thats why i purchased a civic for my engine swap which doesn't have a sunroof... 30 pounds less up top where it counts!
Old Jun 2, 2004 | 06:04 AM
macrosshn's Avatar
the son and the heir
Default Re: Aluminum for exhaust? (dasher)
Zombie---back from the grave. I was definitely going to buy a JIC Bullet but I guess I'll buy a SS version. Can't really afford to spend 500+ on a new exhaust every couple of years.
Old Jun 2, 2004 | 06:14 AM
dasher's Avatar
Default Re: Aluminum for exhaust? (macrosshn)
yep, thats exactly what I was thinking ... Their is a point of diminishing returns, if you have tons of dispossible income then go for it though.
Old Jun 2, 2004 | 06:39 AM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
You wouldn't need to get the aluminum hot enough to melt it, just hot enough to anneal it, because once it is in a soft annealed state it will turn to **** in very short order. This won't happen to Ti in an exhaust, and although Ti is more expensive it is much tougher and much more corrosion resistant.
Old Jun 2, 2004 | 06:46 AM
dasher's Avatar
Default Re: Aluminum for exhaust? (tjbizzo)
TI is brittle and will dent easily however ... but I agree with you that Ti will hold up better then AL...
here is an idea:
... Inconel anyone? $$$$$$$$$$$$$$$$$$$$$$
Reiko
Jul 30, 2008 12:59 PM
gtec8285
May 30, 2008 12:06 AM
B18B1DOHC
Sep 16, 2003 10:50 AM
deviant1
Mar 19, 2003 03:22 PM
spiveslude
Feb 26, 2003 05:35 PM
