Allen head size on ARP studs
Old Jan 14, 2007 | 08:16 AM
B18EG6's Avatar
Default Allen head size on ARP studs
Hello-
A hopefully simple question - What is the size of the allen wrench needed for ARP GSR studs?
Thanks!
Seb
Old Jan 14, 2007 | 08:37 AM
:Josh:'s Avatar
3/16"
Old Jan 14, 2007 | 09:00 AM
B18EG6's Avatar
Default Re: (FourDoorLS)
awesome, thanks!
Is there any way it could be another size?
Old Jan 14, 2007 | 10:08 AM
y7turbo's Avatar
Default Re: (B18EG6)
take the stud with you when you go to buy it. that way you will know for sure what size it is
Old Jan 14, 2007 | 12:14 PM
non-VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18EG6 &raquo;</TD></TR><TR><TD CLASS="quote">awesome, thanks!
Is there any way it could be another size?</TD></TR></TABLE>
nope.......3/16" is the sise you want
Old Jan 14, 2007 | 04:51 PM
B18EG6's Avatar
Default Re: (y7turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by y7turbo &raquo;</TD></TR><TR><TD CLASS="quote">take the stud with you when you go to buy it. that way you will know for sure what size it is</TD></TR></TABLE>
didnt have the stud with me
It was (obviously) 3/16. I guess I has a crappy set of allen wrenches because I had to borrow a friend's set!
On a slightly related note - I lost two out of the 10 washers that came with the ARP hardware... I noticed that these are spherical washers but the bottom of the nut is flat - why is this? Which side faces down?
Could I cut the heads off the OEM bolts and use those washers you think?
THANKS!
Old Jan 14, 2007 | 09:58 PM
V-SPEC 1's Avatar
Dude, call ARP and order directly from them. It's not expensive at all. I think it's less than a buck a piece.
Old Jan 15, 2007 | 03:48 AM
jameelrose's Avatar
the oem washers wont fit. thery are too small
Old Jan 15, 2007 | 07:14 AM
B18EG6's Avatar
Default Re: (jameelrose)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jameelrose &raquo;</TD></TR><TR><TD CLASS="quote">the oem washers wont fit. thery are too small</TD></TR></TABLE>
yeh thats what I thought... since they dont slide down past the threads
I will call ARP, it was sunday so I figured I would ask
Old Jan 15, 2007 | 07:21 AM
V-SPEC 1's Avatar
}-Black-Ls-Stunna-{
Oct 26, 2008 12:11 PM
Jay J
19
Feb 3, 2005 01:12 PM
boostedcvc
Jan 2, 2004 06:21 AM
Toda Built
Jan 1, 2004 05:24 AM
DC2_Integra
Oct 20, 2003 07:39 PM
