Alchol injection rebuilds??
I suppose if you are running straight alcohol or meth it might be true. If you are injecting straight alky or meth you just have to add lubricant (just like lube is already added to gasoline).
Alcohol and methanol are VERY corosive. We change the oil and filter after every time we take it to the track. Also run gas through the motor to get most of the alki out. It was cause the crank, rods, and everything to rust. I recommend to changed the oil and filter everytime you run it.
square_1
Nov 28, 2008 10:17 AM
