air filter for turbo
Old Dec 9, 2002 | 04:52 AM
rbf351's Avatar
Default air filter for turbo
how can i connect a filter to my turbo?
i have no space to fit anything in there
Old Dec 9, 2002 | 05:14 AM
Dancing is Forbidden's Avatar
Default Re: air filter for turbo (rbf351)
What is that in? What mounts did you use?
Old Dec 9, 2002 | 05:15 AM
Optiks.'s Avatar
get rid of your ac
Old Dec 9, 2002 | 05:18 AM
rbf351's Avatar
Default Re: air filter for turbo (Optiks)
i need the AC otherwise i would have pulled it, would have made intalling it much easier
and it's a revhard stage 2 kit
either way there seems to be no room to put a filter or peice of pipe over there. it looks like it will hit the slave cylinder bleed nipple
Old Dec 9, 2002 | 05:25 AM
Brandon Clifton's Avatar
Advance Auto Parts radiator hose part number C71216 works on my T3.
Old Dec 9, 2002 | 05:28 AM
I bet you could just hook up one of thoe HKS mushroom filters right on the turbo. Looks like you've got a little room there. And Why do you NEED A/C? I live in Charleston, SC AKA 100 degrees and 100% humidity with no A/C.
Old Dec 9, 2002 | 05:36 AM
rbf351's Avatar
Default Re: air filter for turbo (EF9_SiR)
i tried getting and old K&N filter that i had that fits perfectly on the end of the turbo, but there is just no room for it to fit, i don't even think the HKS one will fit without some type of tubing
Old Dec 9, 2002 | 05:45 AM
PM-Performance's Avatar
get some kind of piping to arch it up more . that might work . or make it a cold air with some piping ?get it out of the bay totally
Old Dec 9, 2002 | 05:50 AM
zojirushi's Avatar
Default Re: air filter for turbo (itr206)
i think the only way to get a filter and pipe in there is if u remove the radiator fan. I also have a rev hard manifold and the inlet for the turbo is soooo close to the motor of the fan. any attempt to place a filter there is futile.
Old Dec 9, 2002 | 06:08 AM
rbf351's Avatar
Default Re: air filter for turbo (zojirushi)
what i'm doing now is looking for a pusher fan so i can fit the piping or filter in there
does anyone know where i can get these fans from?
Old Dec 9, 2002 | 06:11 AM
Arturbo's Avatar
Better than steak
25 Year Member
It looks like it wont fit, but one will. I thought I wouldn't ever be able to get one on with mine and we got one on there.
Old Dec 9, 2002 | 06:32 AM
01ITR#700's Avatar
Default Re: air filter for turbo (Arturbo)
I got a silicone rubber elbow and trimmed it down on one side and it worked like a charm. That way the end I shortened fit onto the turbo and the other end shot straight up. I then built a custom 3" mandrel intake from there.
M
Old Dec 9, 2002 | 08:15 AM
Sprockets's Avatar
There has to be something here that will fit:
http://www.knfilters.com/universal/univrndtap.htm
Old Dec 9, 2002 | 08:25 AM
rbf351's Avatar
Default Re: air filter for turbo (Evil Beaver)
looking at that list, i'm sure something will just not sure which one
anyway
i ordered pusher fans so i should have alot of extra space to place with now
Old Dec 9, 2002 | 08:43 AM
boostedcvc's Avatar
where did you order your pusher fan from?
Old Dec 9, 2002 | 08:46 AM
rbf351's Avatar
Default Re: air filter for turbo (boostedcvc)
got them from jcwhittney.com
both are 11" pusher/puller fans
Old Dec 9, 2002 | 08:55 AM
RAWB's Avatar
Before I relocated my battery- I used a motorcycle filter. Worked good.
Since I moved the battery, I used some flexible exhaust tubing from Pep Boys and some plumbing adapters from Home Depot(2.5" over the compressor and 2" over the tubing and vice versa for the filter side) I've been using it over 2 years- no probs. Also, don't be afraid to trim some of that fan backing, as well.
Old Dec 9, 2002 | 10:02 AM
LOwrestling2001's Avatar
Default Re: air filter for turbo (integracon)
try this for now.
http://www.imagestation.com/album/?id=4291042789
i just cut a piece off a generic intake, slapped on the filter, and crammed it in there for now. eventually i want some drag piping to put on and move it over towards the passenger side like drag kits.
Old Dec 9, 2002 | 10:21 AM
rbf351's Avatar
Default Re: air filter for turbo (ViNhLaDeN)
that would probably work now i just have to get some piping
Old Dec 9, 2002 | 11:06 AM
AVATAR's Avatar
How much were the pusher fans? Tried Autozone yet?
Old Dec 9, 2002 | 11:16 AM
rbf351's Avatar
Default Re: air filter for turbo (AVATAR)
i was too lazy to drive to autozone and their website sucks and i couldn't find anything on there. so jcwhittney was where i found ones
Old Dec 10, 2002 | 03:39 PM
zojirushi's Avatar
to people who have pusher fans:
Do you still have your a/c condensor and the pusher fan is mounted on that or did u remove the condensor?
Old Dec 10, 2002 | 04:00 PM
AlphaKennyWun's Avatar
good question, been wanting to know this myself.
Old Dec 11, 2002 | 10:12 AM
zojirushi's Avatar
Default Re: air filter for turbo (SO3Burner)
ttt
Old Dec 11, 2002 | 10:55 AM
rbf351's Avatar
my pusher fans will be here tomorrow
from what i've been reading you Zip tie your condensor to the car if you have a civic, not sure how it would work for an integra
