Ahaha, figured out the problem.
Old Mar 19, 2002 | 10:14 PM
  #26
DeeJay's Avatar
New User
Default Re: Ahaha, figured out the problem. (dustin)
f-max did the same **** to me, I was able to tell when i first looked at the turbo. I sent it back to them and made them send me a stage 3 63 ar. My car feels strong, I haven't dynoed it yet but the torque steer pulls the steering wheel out of my hands.
Old Mar 19, 2002 | 10:47 PM
  #27
Rain_man's Avatar
New User
Default Re: Ahaha, figured out the problem. (DeeJay)
Dustin, didn't you say you were hitting full boost about 4100 rpms? That seems kinda laggy for a smaller turbo.
Old Mar 19, 2002 | 10:49 PM
  #28
dustin's Avatar
Default Re: Ahaha, figured out the problem. (DarksideDC4)
I thought I was... but I went out today on the highway and I was able to hit full boost before 3500rpm... heh. I had never paid attention before I guess. My old turbo hit full boost about 4000.
Old Mar 19, 2002 | 11:40 PM
  #29
degradated's Avatar
New User
Mine is stamped 20359....what the hell do I have?
Old Mar 20, 2002 | 12:43 AM
  #30
dbman96's Avatar
New User
Looks a LOT like my dyno run with an 0.48 on my GSR. Sucks, don't it?
Old Mar 20, 2002 | 12:56 AM
  #31
Markaccord95's Avatar
Default Re: Ahaha, figured out the problem. (dbman96)
nice airfuel ratio there
Old Mar 20, 2002 | 12:57 AM
  #32
most turbos will have the AR stamped on the inside of the exhaust housing inlet, look there.
Old Mar 20, 2002 | 09:44 AM
  #33
Seraph0's Avatar
Default Re: Ahaha, figured out the problem. (Markaccord95)
Dustin if you measure the I.D. of the turbine outlet it should be 2.25". Somewhat less than that for a Stage2.
It LOOKS like a Stage2 just judging by the excess machined flat metal around the turbine.
The housing LOOKS like a .48 too. .63's are more "beefy" looking....ha
Old Mar 20, 2002 | 10:15 AM
  #34
93LSivic's Avatar
Default Re: Ahaha, figured out the problem. (lucas569)
thats the same exact turbo i bought from maxrev! get it ! this way you can email me your rom tune figures! I'm getting an entirely new turbo. It's a stage2 wheel =P
I'm thinking 57trim to4e/t3 .63 stage 3 wheel btw get the new style flanged turbo!
Ditto same turbo I bought from Maxrev also. I hope it will be ok for my stock redline'n LS motor........
Old Mar 20, 2002 | 11:25 AM
  #35
dbman96's Avatar
New User
Default Re: Ahaha, figured out the problem. (93LSivic)
0.48 should flow plenty for a stock LS engine
Old Mar 20, 2002 | 11:43 AM
  #36
InfamousRS's Avatar
Dustin. what are you going to be doing with these 2 extra turbos you have?
Old Mar 20, 2002 | 12:42 PM
  #37
BLKMamba's Avatar
BMW Güdentyte
25 Year Member
Default Re: Ahaha, figured out the problem. (BLK94RS)
Dustin!! I always wondered why yours was putting out so low on the dyno especially on your setup and would imagine, you would be up par with Art or even more!! Sorry Art, not dissing you or anything.
Now, we'll see how much more you can put up with with the corrected spec turbo and for once, please run your car at Sac!!
Old Mar 20, 2002 | 12:57 PM
  #38
Ben Huynh's Avatar
Default Re: Ahaha, figured out the problem. (DB8GSR)
Look on the inside of the turbine for the correct A/R number. Disregard the number on the outside.
Old Mar 20, 2002 | 11:13 PM
  #39
dustin's Avatar
Default Re: Ahaha, figured out the problem. (ben@importparts.com)
It's a serious pain to pull the turbo off to see the stamp... Outlet is 2.25" maybe a little less, hard to get an accurate measurement. It's a .48 housing for sure.
I get full boost by 3500 with this turbo heh... so I know it's not the right one.
Old Mar 21, 2002 | 12:04 AM
  #40
DLB1994's Avatar
i had a .48 and went to a .63 i got the same rpm spool up with the .63 but the .48 had a lot more mid power and the .63 the power is more in higher rpms
Old Mar 21, 2002 | 12:14 AM
  #41
dustin's Avatar
Default Re: Ahaha, figured out the problem. (DLB1994)
What wheel though? I have no top end now ... hehe
Old Mar 21, 2002 | 05:10 AM
  #42
1's Avatar
DRAG has sent me the wrong turbo twice...
I'm not surprised, better to go buy your own
Old Mar 21, 2002 | 06:07 PM
  #43
The Mick's Avatar
Hey dustin,
Check out the chart in the link below in the T3 section labeled EXDUCER DIA.
You can measure the outlet diameter with some calipers, then take some feeler gauges and gently measure the gap from the blade to the outlet. Multiply the gap by 2 and subtract from the outlet measurement to obtain which stage you actually have. Or this...
~(2.250" - 2.122") / 2 = roughly .064" gap = stage 2 wheel
or...
~(2.250" - 2.229") / 2 = .010½" gap = stage 3 wheel
http://www.turboneticsinc.com/catalog/twheel.html
Good luck fella! I hope you get it all straightened out soon. I can't wait to see some real numbers, especially since you seem to do things the "right" way. I'm still diggin' your fuel set-up!
Take care,
[Modified by The Mick, 10:10 PM 3/21/2002]
[Modified by The Mick, 10:43 PM 3/21/2002]
Old Mar 21, 2002 | 06:21 PM
  #44
dustin's Avatar
Default Re: Ahaha, figured out the problem. (The Mick)
I'm yanking the stupid turbo off tonight and measuring everything!
Old Mar 21, 2002 | 07:20 PM
  #45
The Mick's Avatar
Atta-boy! I wouldn't take anybody's word for it (if there's a way to measure it). When I got my kit, it seemed like it was some big secret as to which trim level, etc. the GS-R Drag kit came with, so I measured everthing for myself. Now it's a known fact which trim they should come with. Unfortunately for you, somebody goofed twice.
Let me ask you this... what levels are you planning to boost to once you get everything squared away? I've been looking at several compressor maps and it appears to me that a T3/T04E "50" trim compressor and A/R .63 stage 3 turbine would be best suited (if not ideal)to a GS-R motor in the 10 to almost 20 psi range. I wonder why most people seem to prefer the 57 trim and 60-1? I know which one I'd choose. Just somethin' else to think about when you order your next turbo. Do the math and see which setup is best for your goals.
Old Mar 21, 2002 | 08:10 PM
  #46
dustin's Avatar
I want the 57trim because art has one
Old Mar 21, 2002 | 08:36 PM
  #47
Arturbo's Avatar
Better than steak
25 Year Member
Did my dyno chart do it for you? hehe...
art
rice a roni
Sep 15, 2015 07:19 AM
Rooftop voter
Mar 6, 2009 06:46 PM
Nextelbuddy
Jun 26, 2004 05:38 AM
lucas569
Dec 1, 2002 11:12 PM
Full-Race Geoff
Nov 18, 2002 11:31 AM
