Ahaha, figured out the problem.
Thank's kabir!
See if you guys can figure out what it is, too:
First, look at this list:
. 36 STANDARD 20369-72 430410-0011
STAGE II 20369-02 N/A
STAGE III 20369-03 N/A
. 48 STANDARD 20357-72 431262-0012
STAGE II 20357-02 N/A
STAGE III 20357-03 N/A
. 63 STANDARD 20358-72 430225-0013
STAGE II 20358-02 N/A
STAGE III 20358-03 N/A
. 82 STANDARD 20376-72 N/A
STAGE II 20376-02 N/A
STAGE III 20376-03 N/A
Then look at this unimpressive dyno:
Then look at this turbo pic:
Hehe!
Hehe!
yup.. choking up your potential. I can't tell from the pic, but do you have the Stage II or III? Cuz you'll have to get the same stage in .63 form unless you want to change the turbine wheel too.
Thank's kabir!
Hehe!
Hehe!
ok i'm out in left field on this one, somebody clue me in on what we're seeing here.
what is the dyno depicting? the difference between a .63a/r and .48a/r turbine with stage 3 wheels?
EDIT: i see the 20357 stamped near the inlet flange on the turbine. ok i see what you are talking about now.
[Modified by cyan1de, 8:05 PM 3/19/2002]
that would explain it!
so where does your turbo spool up?
what are your compressor dimensions?
can someone please explain the differences between the stage 2 and 3 wheels? seems like everyone always gets the stage 3 wheel; why would you ever want the stage 2 or stage 1?
-Xerxes
-Xerxes
That 20357 doesn't seem to mean anything. Or if it does, I don't know what it is. I thought my turbine housing was a .48 a/r for a while because it had 20357 stamped on it as well, until I found .63 stamped on the inside. 20357 seems to be stamped on all the turbonetics turbines.
But look at the space between the turbine blades and the housing... def not a stage 3 wheel... Is the one with the raised block '2' at the beginning the one that determines the part #?
This housing wasn't stamped .63 on the inside.. wasn't stamped at all on the inside actually.
Hehe!
Hehe!
-Jamison
Mine says .50 ar is that small? I think it is!!!!
Also - it has 11 blades on the exhaust side (I think) and 6 on the other side(intake)
So could someone tell me what turbine I have....I think I remeber seeing .63 stamped on the inside of the exhaust housing.
[Modified by SlowB16, 2:11 AM 3/20/2002]
[Modified by SlowB16, 2:12 AM 3/20/2002]
Xerxes,
Go here to see the dimensions showing the differences between stage 2 & 3:
http://www.turboneticsinc.com/catalog/twheel.html
and
http://www.turboneticsinc.com/catalog/thousing.html
dustin,
I'm surprised that you didn't measure your wheels, especially after getting the wrong parts last time.
I think you're just lookin' for an excuse to run that A/R .82 turbine and pull the big numbers on the dyno (assuming you can stand the lag).
Take care,
[Modified by The Mick, 12:16 AM 3/20/2002]
and
dustin,
Take care,
thats the same exact turbo i bought from maxrev! get it ! this way you can email me your rom tune figures!
btw get the new style flanged turbo!
I'm getting an entirely new turbo. It's a stage2 wheel =P
I'm thinking 57trim to4e/t3 .63 stage 3 wheel
