aftermarket Fan switch?
Old Oct 30, 2009 | 11:48 PM
kmaz93da's Avatar
Default aftermarket Fan switch?
car is gsr turbo on hondata s300, 180 thermostat, cars always in 200-210 temp zone, looking to keep temp down in 185..any one makes an aftermarket fan switch? or should i jump fan switch plug and keep fan on all time?
Old Oct 31, 2009 | 12:43 AM
SlowReaction's Avatar
Default Re: aftermarket Fan switch?
At what temp does the fan usually kick in? You should still be able to control the fan through the s300, you dont need to add any relays.
Old Oct 31, 2009 | 02:47 AM
cbustuner's Avatar
That's what I was going to say. I've seen a few cases where a relay was needed, but on most cars you don't need to do any additional wiring.
I didn't need to do any wiring on my car with ectune or crome free,and I don't see why hondata would be any different.
Old Oct 31, 2009 | 12:55 PM
kmaz93da's Avatar
believe all stock honda fan switches are 210,which mine is,but a tuner told me that s300 dosnt have a fan overide,(k-pro does)but can use any auxilarry outputs to control it with a relay, but it would b easyer to run the fan constant by jumping plug wires
Old Oct 31, 2009 | 01:00 PM
Dcteg94's Avatar
Personaly i would run the fan constant with the power you are makeing. I dont know of any aftermarket companys that sell a lower fan switch at this point.
Old Oct 31, 2009 | 02:35 PM
95dc2teg's Avatar
there is a fan overide that you can use in hondata s300. go to perameters then protection at it is at the bottom. You can over ride it and set it to what temp you want it to come on. who is your tuner?
Old Oct 31, 2009 | 05:44 PM
kmaz93da's Avatar
o, thanks alot! i found where its at...havent tuned yet, driving on base map
Old Nov 1, 2009 | 04:33 PM
postman's Avatar
if u plan on running it constant. id use the stock or a good aftermarket fan. the cheapos will break quickly
Old Nov 2, 2009 | 10:03 AM
kmaz93da's Avatar
hav a FAL fan, half size rad. 2" core, and figured out s300 has fan overide, so im going play around and figure best temp for fan, guessing between 185-190
Old Nov 2, 2009 | 10:59 AM
boxeocampeon's Avatar
get a fanswitch from mishimoto
Old Nov 5, 2009 | 10:30 AM
kmaz93da's Avatar
pluged in my s300 from laptop and went parameters and protection, clicked on fan overide, Did Not work, cause fan has constant power, and fan switch gives it ground, so i think going have to buy aftermarket fan switch, spoon,mugen makes them too.... there 80^ C which = 176^F...only difference between jumping fan switch plug and the aftermarked switches is fan wont b on til 176 wich will warm up faster, as if i connect the plug wires and run constant, take longer to warm up until thermostat opens.
f15Civic
Mar 9, 2017 05:45 AM
95WhiteTeg
Sep 2, 2011 05:55 PM
Natural Aspirations
Engine Management and Tuning
18
Mar 1, 2011 12:48 PM
ViXoN Hatch94
Feb 4, 2006 07:53 PM
